Car just kills while driving???
Old Jul 7, 2015 | 09:59 PM
stein3282's Avatar
stein3282
Default Car just kills while driving???
My car 06m6 just randomly kills while driving. No check engine lights or anything. Put the car in neutral and it fires right back up while coasting. Anyone experienced this?
Old Jul 7, 2015 | 10:27 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Some details would likely help.
Is the car stock?
Original tune?
M6 or auto?
Does it do it while just driving down the road? Coasting? Engine braking?
Old Jul 7, 2015 | 11:28 PM
djbrun's Avatar
djbrun
So your electrical power is still there, the engine just shuts off?
DJ
Old Jul 8, 2015 | 06:16 AM
stein3282's Avatar
stein3282
Car is M6 cammed. When it kills, its not just the engine. Everything goes off like it was sitting in the garage. Fires right up when I hit the start button.
Old Jul 8, 2015 | 07:53 AM
zali0104's Avatar
zali0104
Check for body and communication codes. This will give an idea of which module is loosing power or ground. Code will say "loss of communication with module X."
Note, a hand held code reader will not work. Will need a real scanner or tech2
Old Jul 8, 2015 | 09:55 PM
djbrun's Avatar
djbrun
I would start with a wire wiggle of the power wires while doing a voltage drop test. Sounds like it could momentarily losing battery voltage.
Old Jul 8, 2015 | 11:16 PM
ChevyDave's Avatar
ChevyDave
i tried search, because i read this problem about 3 years ago, it was the battery cable connected at the starter.
problem is i cant remember if the nut was not tight or the entire lug at on the starter was broken and sorta loose. either way, they reached the starter terminal/battery cable lug and wiggled it (with NO finger rings on) and found it (?) loose
Old Jul 9, 2015 | 06:33 AM
stein3282's Avatar
stein3282
This makes the most sense to me as it just started happening after I had longtubes installed on the car. The one mod I did not do myself. Guess I will be getting under there and checking for some loose wires.
Old Jul 11, 2015 | 02:06 PM
djbrun's Avatar
djbrun
Did you check all your power wires, Including the negative side of the circuit?
DJ
Old Jul 12, 2015 | 10:01 AM
ray_ray's Avatar
ray_ray
A friend of mine had same issues..ground wire at battery was corroded really bad..inside the coating..couldn't tell till he took it off. replaced with new cable solved the problem.
Old Jul 12, 2015 | 10:04 AM
Phillip123's Avatar
Phillip123
It's probably something regarding the battery... not sure.
Old Jul 14, 2015 | 05:44 AM
stein3282's Avatar
stein3282
Thanks guys. I have not had a chance to troubleshoot yet, but thanks for all the suggestions. I will post once I find something.
Old Apr 13, 2017 | 03:30 PM
Wes Burch's Avatar
Wes Burch
Same problem a few years ago. Finally tested out to be a bad engine ECM. Replaced - problem gone.
Old Apr 13, 2017 | 07:26 PM
sallen619's Avatar
sallen619
​​​​​​Sane thing was wrong with mine also...I got a new ECM.
To Car just kills while driving???
