Brake pedal spring?
But what do you mean that it floats up?
When the ABS kicks in to just stop the tires from locking up when braking, you should feel the brake pedal start to pulse/chatter rapidly instead.
If the active handling kicks in, then the ABS pump kicks in to send more brake fluid pressure to one or more of the brake calipers to slow the needed tires down to straighten the car out instead (will slightly push the brake pedal back up).
I would start with pulling codes, and if you have not power flushed the brake lines in a few years with new brake fluid, now would be a good time to do so. Also, to get all the old fluid out of the ABS pump, it take a Tech II to cycle the pump as you are power flushing the brakes. Short of this, power flush with new fluid to get all the old fluid out you can can, find an area that you can get the active handling to kick on during hard braking to cycle the abs pump to push the old fluid out of the pump and suck in new fluid, then powder bleed again.
