CPU Problem HELP!
The two black plugs in a row in the lower center of the photo on the front passanger side of the trans is the reverse light switches (again, two of them and look close at the photo see both of them since once is just above the other and the trans is sitting with the rear of it to the left, and front of it as it will sit in the car to the right).
NO KEY FOB DETECTED is kind of normal for me, and it just a matter of lifting up my hip in the seat with the fob in that pocket so the RCDLR antenna's can see it to start the car. As for shut down, just get lazy instead of lifting my hip and just hitting the off position on the starter button a second time with the car in reverse instead.
PS, it not CPU, there is the BCM involved in this mess when the car can not see the reverse switches in the correct positions to allow you to put the car into sleep mode.
