Driver Headlight Doesn't Work Even After Bulb replacement
Old Jul 18, 2015 | 07:41 PM
dheck's Avatar
dheck
Default Driver Headlight Doesn't Work Even After Bulb replacement
My drivers side headlight will not come on. I thought it was a bad bulb so I replaced it and it did not make a difference. I checked all the obvious fuses and they seem fine. Any ideas on where to look next?
Old Jul 18, 2015 | 10:46 PM
Jtaugner's Avatar
Jtaugner
Have you tested the Ballast to see if it's working?
Old Jul 19, 2015 | 07:43 AM
zali0104's Avatar
zali0104
Have you checked the fuse? Each headlight has it's own fuse.
Old Jul 19, 2015 | 10:57 AM
dheck's Avatar
dheck
I checked both fuses and the relay and they seem fine. Is there a way to test the ballast?
Old Jul 19, 2015 | 11:25 AM
zali0104's Avatar
zali0104
Switch ballast to good headlight.......
To Driver Headlight Doesn't Work Even After Bulb replacement
