Driveline HP Loss
Old Jul 21, 2015 | 09:07 AM
ksurfer2's Avatar
ksurfer2
Default Driveline HP Loss
It is generally agreed that there is about a 15% HP loss between the crankshaft and the rear wheels. The 436HP LS3 makes about 380HP at the wheels, or a loss of 56HP. Lets assume that the engine is then modded and dyno'd at 490HP at the rear wheels. Does the 15% horsepower loss rule still apply which would mean approximately 563HP at the crank or, since no other changes were made in the driveline the original loss of 56HP would still be the rule which would mean 546HP at the crank.
Old Jul 21, 2015 | 11:04 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
It's hard to say because I think the number of people who have their engine dyno'd alone after doing a few mods is quite low.
My gut feeling is that you'd "lose" the percentage.
Old Jul 21, 2015 | 11:33 AM
Dano523's Avatar
Dano523
No, the drive line power lose is a constant, and the % amounts are based on stock power lose alone.
So on a say a manual trans C6, you have about a 61HP lose through the drive line. As the HP it increased through mods and no changes to the drive line, the drive line lose stays at the same 61Hp lose.
Old Jul 21, 2015 | 01:42 PM
brewcitygymratt's Avatar
brewcitygymratt
St. Jude Donor '13
Are you implying that if someone had 900rwhp after modding a c6, they would have 961 @ the crank instead of 1059? I've only ever heard that the drivetrain loss % was the constant. Roughly 15% for manual trans based on the final hp level, 18-20% for automatics.
Old Jul 21, 2015 | 02:02 PM
ksurfer2's Avatar
ksurfer2
I would assume that for a 1000hp car, there were substantial changes made to the driveline to support that power that may change the 61hp constant. In my example, the drive line would stay as stock. It makes sense (at least in my head) that if nothing in the drive line changes that the HP loss would remain the same after the engine was modded.
Old Jul 21, 2015 | 03:39 PM
JakeC6Racing's Avatar
JakeC6Racing
I always considered the loss to be a percentage, not a fixed number.
Old Jul 21, 2015 | 03:46 PM
ksurfer2's Avatar
ksurfer2
What would cause the total HP loss to the drive line to increase as engine power increased if no changes to the drive line were made?
Old Jul 21, 2015 | 05:26 PM
Mike's LS3's Avatar
Mike's LS3
Drive line meaning - wheels/tires/brakes, differential, transmission, clutch assembly, drive shaft, then the answer is nothing! Power train loss is constant.
Even adding horsepower using a supercharger will not affect powertrain loss. Adding a supercharger will increase the loss of HP at the flywheel, but the loss will be more than compensated by the overall gain in HP.
Old Jul 21, 2015 | 06:10 PM
Boomer111's Avatar
Boomer111
Manuals seems to be closer to 12 1/2% for the C6 anyway.
Old Jul 21, 2015 | 10:58 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I don't know if you can go by "conventional wisdom" or anything that is not factual, based on a particular car/engine, and then backed up by proof of many examples. After all, unless I'm very wrong, I've not heard of a <5% loss from an entire drivetrain, but look at these two posts over on C7Z06:
Post 39 and 40
"Tripleblk6spd
I have dyno'd a half a dozen stock c6 Z's, and they all make 480ish to the wheels with the average at about 483. I am talking on the same dyno to my c7 z."
"Realistic dyno? The only dyno I trust is the one that is consistent and agrees with the trap speed at the track, and that is a dynojet. Doesn't matter which dyno you use, the delta is the same! My c7 made 531whp on hot pulls stock. The c6 Z's I have dyno'd make 480's stock. BOTH cars trap 126 to 127 in the AZ heat... Do the math, my c7 scaled 3550 without driver, the c6 Z's scale about 3150 without driver. It all agrees. I have used every dyno out there on numerous occasions tuning cars all over the country, and only one will NAIL the trap speeds consistently, and that is a Dynojet."
That was in answer to my question to what he stated as fact that a stock C7 Z06 making 650 crank horsepower (chp) LOSES 130 chp and would dyno on a hot lapping road course at 530 rwhp---which is about a 20% loss from 650. But, the most important part is that he said he regularly sees C6 Z06s dyno at 480 rwhp for a car that has chp of 505---and that is less than a 5% drivetrain loss. If anyone else has seen that number/figure, please advise because I haven't yet.
Long way of saying, there are many answers to the question of drivetrain loss, loss factor, rules of thumb, etc.
From this thread: https://www.corvetteforum.com/forums...ped-for-2.html
Old Jul 21, 2015 | 11:21 PM
Mike's LS3's Avatar
Mike's LS3
Post 39 and 40
"Tripleblk6spd
With a heat soaked supercharger, the flywheel horsepower could easily be down 50 hp which would translate into lower rwhp #'s.
The C6 ZR1 has dyno'd 550 -560 rwhp and with 638 hp at the crank. That is a 78-88 hp loss at the wheels which in line with a 12% loss with a manual transmission.
There are You Tube videos with stock C6 Z06's pulling around 440 rwhp which is in line with a 12% rwhp loss.
480 rwhp on a stock C6 Z06 seems high.
There are documented dynos on C7 Z06's with 572 rwhp also in line with a 12% loss. A heat soaked C7 z06 engine can easily drop to 531 rwhp.
Dyno readings have to be compared with conditions being equal.
Old Jul 22, 2015 | 12:18 AM
Boomer111's Avatar
Boomer111
I have always read the C6 Z06 dynos low mid 440's. Right in the 12.5% area again. 505 hp flywheel.
My LS3 showed 12.5% on a wheels off dyno.
Talking manual trans of course.
Old Jul 22, 2015 | 07:33 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Yes, and I don't see that happening in the posts I quoted above in the bolded part. And if you're saying a 650 chp engine can drop 12% and then another 50 rwhp due to track-related heat, ok.
Old Jul 22, 2015 | 09:26 AM
HC Mechanic's Avatar
HC Mechanic
That would be the best way to test it
Old Jul 22, 2015 | 10:39 AM
Mike's LS3's Avatar
Mike's LS3
Yes, especially boosted applications!
To Driveline HP Loss
