Dead battery 2005 AGAIN
Good luck!
You really can't compare it to your pickup... C6's are harder on batteries than most cars.
If you still have the old Optima contact OptimaJim on this forum, he may be able to give you some pointers to recharge the battery. Sometime alternate techniques are required on a deeply discharged Optima.
I installed the 3rd Red Top Optima in the 69 in March 2014, but when I replaced the C6 battery a month later I went to a standard battery with an 3 year free replacement and 84 month warranty, much better warranty than Optima.
So far it looks like 2 to 3 years is the typical life for a battery on a vehicle with infrequent use even with the use of a Battery Tender. As of 4/2014 my 08 has had 3 batteries since built in 1/2008 and my 69 has had 3 batteries since 10/2008. Some swear they have had batteries last 10+ years but that is certainly has not been my experience.
If so that is the issue and it is a common problem. here is what I know--
the 2005 year has a reverse / steering wheel lock circuitry that by 2006 was eliminated and is thought to be the source of the mysterious drained battery syndrome. I have seen several 2005 corvettes when the system starts to go bad the battery will drain regardless if it is in reverse.
I have a deep cycle marine battery that my Diehard battery minder will keep charged, so my question is will that work in the Corvette? It is a 2008 with no modifications and like I said it is driven very infrequently. My original battery worked well with just plugging the battery minder into the power outlet in the center console.
Lets go through the check list.
Do you have Onstar on the car, but no service for it ? If yes, then chance at it's cycling at night when the car is in sleep mode, and that is draining the battery.
The solution is to unplug the onstar vcim module if you are not using the onstar in the car, and jump the lan bus wires on the connector once you unplug it.
And the VCIM is in the passenger back cubby hole on the front side behind the carpet inside the cubby hole under the lid.
Ditto goes for the XM radio, and if you are no using it, then unplug the XM module.
The module is above the rear driver side wheel well behind the carpet.
Next, lets check the charging system.
Start the car, and with a multi meter set to DC, get a reading on the alternator. Hence body of the alternator is the ground, and the terminal on the back of it under the rubber boot is the positive.
The voltage you are looking for is 14.6 volts and take a reading from the terminal itself, and not the wire connector bolted to the terminal instead.
Next with the car running still, take a reading at the battery terminals. Voltage here should be 14.5 volts.
Next, pop the fuse box lip open, and take a reading of the positive terminal at the fuse box, to the body of the alternator as the ground point. Reading should be 14.5 volts.
Lastly, toggle the DIC to voltage, and the voltage should be 14.3 volts (or higher).
If you get a low reading anywhere, tell me which one and I can tell you where the problem is in the charging system wiring and how to fix it.
As for if you are not going to drive the car for a few days, get it on the battery tender!!!! Even with a fully charged battery, the Vet will drain a battery down in about three weeks flat when left in sleep mode/sitting parked.
Lastly, when starting the car, it take about 15min for the car to fully charge the battery again when being driven. If you are driving the car for short distances and turning it off/starting it up for another short drive again, the battery may end up not being fully charged when you shut the car off for the day. So here, just throw it on the battery tender for the night to charge the battery back up again.
Bluntly put, the longer is the battery is in a fully charged state, the longer the battery is going to last. So since the car charging system has more than enough power to keep the battery full charged if working correctly when the car is running, then problem with a battery wearing out so fast is something is either not allowing the battery to fully charge in the first place with the car running, of something is draining it quickly when the car is in sleep mode instead.
