C-6 Air bag light on
Old Jul 28, 2015 | 10:40 PM
Largebolivar63's Avatar
Largebolivar63
Default C-6 Air bag light on
Anyone have this issue? Air bag light came on at 9800 mi. Took in under warranty but dealer was unable to fix after 3 attempts.
Old Jul 29, 2015 | 12:10 AM
Wampa's Avatar
Wampa
My air bag light came on first week of ownership (used at under 25k miles). I found common remedy on this forum that fixed my issue; and hasn't returned for almost 2 years. Yellow connector under driver's seat comes loose. Run seat far forward to access harness underneath and re-seat connection. I also zip-tied mine closed. I'm sure there could be other causes; but simple, free thing to check. Good Luck!
Old Jul 29, 2015 | 12:58 AM
C6topless's Avatar
C6topless
likely your seat is too low.. raise the seat
Old Jul 29, 2015 | 08:04 AM
dentalfloss's Avatar
dentalfloss
I had the same problem and it was the the plug connection under the back of the seat. I tried fixing the plug connection and finally gave up. I bought a trailer flat 4 prong plug kit. I cut, soldered and used heat shrink. I have no more airbag light on.
To C-6 Air bag light on
