cooling system and air pockets ..
Old Aug 6, 2015 | 01:54 AM
C6topless's Avatar
C6topless
Default cooling system and air pockets ..
As our C6 become older, many owners I know are changing out their water pumps and hoses and doing a complete cooling system flush ( really an easy job on the corvette no one should be afraid to tackle ).
If you do this, however, please be aware that the placement of the water pump facilitates cavitation ( air pockets that prevent proper coolant flow ) ... and the procedure outlined in the service manual to remove these air pockets may not work.
You can tell if have an air pocket if you run your corvette after a coolant flush and you see your temp gauge climb really rapidly -- and hit unusually high temp readings.
If you do have an air pocket that is tough to remove, you will need to negative pressurize/fill. I personally use the UView 550000 Airlift Cooling System Leak Checker and Airlock Purge Tool Kit. some auto parts store will loan you this tool --- really easy to use and works great.
Old Aug 6, 2015 | 06:52 AM
MARSC6's Avatar
MARSC6
Or you can just suck on the hose going to the coolant reservoir.
Dexcool has a horrifically foul taste so be careful if you try.
Old Aug 6, 2015 | 08:45 AM
timd38's Avatar
timd38
I am more of Cabernet guy than a Dexcool!
I bought the tool, works great.
Old Aug 6, 2015 | 12:54 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Agree on both counts, lol. It works in a pinch, though.
To cooling system and air pockets ..
