Did a fluid change of my manual shift 2008 tranny/dif.. Allegedly this should entail 3.5 quarts. Neither did this drain out, nor did it go in. It took 2 quarts. Yes, the car was raised as straight as can be. Rhino ramps up front and two supports in rear. Need I worry? Please your advise please.
Very curious. I have done four fluid changes on both T56 and T6060 trannies and it always took 3.5 to 3.75 qts. Only taking 2 quarts leads me to wonder if you got a good drain. Did you open the FILL connection and remove plug to allow the housing to vent when draining?? If not, you may have gotten the classic upside down coke bottle effect and not allowed all of the fluid to drain.
I took out the fill plug first. The only thing is I didn't put a level on the roof?
My first question would be: Did you change the differential fluid by mistake and not the trans? Dif w/plugs at rear takes 2 qts vs trans w/plugs at side takes 3.65 qts (non Z51)
Most garage floors taper down 1/8" per foot toward the door to provide drainage. That can be a thing to consider if the surface you raise the car from is not level, you need to compensate for the difference.
I don't want to mention a dirty word, but the "owners manual" states like 3 qts for a "new" fill and 2 1/2 for a refill
Yeah. I was only stating the data from an '08 service manual section 17-362, because the '08 owners manual on page 5-103 rounds it off at 3.6 qts.
You know, the service manual, it's the one that the dealer service techs use for '08's like the OP has.
I use a level against the bottom of the floorboards checking both right and left hand sides. But to get the best drain, the front of the car needs to be higher than the rear since the drain plug is on the passenger side rear of the housing.
That would not be good to replace the diff fluid with ATF.
Oh boy you nailed it. I removed that drain from the rear. I thought tranny and rear differential one and the same. Now I'll have to drain that ATF out of there. What do you suggest?
Ouch. The tranny and diff housings are completely separate with two different spec fluids. The diff fluid to use will be 75W90 DEXRON LS. Starting with MY2009, that became the standard factory fill for all corvettes. DEXRON LS is recommended for older corvettes as well especially if they suffer from low speed turn chatter. An alternative fluid that I have had great success is AMSOIL Severe Gear 75W90. If the car was previously chattering, a 4 oz bottle of slip lock additive will be helpful. Both DEXRON LS and the AMSOIL Severe Gear both have slip lock additive already in the fluid mix.
Just to be clear for the Differential Housing fluid, the FILL plug is facing rearward toward the right hand muffler and the Drain is on the very bottom of the housing facing downward. The Tranny Housing FILL plug is on the upper left side facing toward the driver door with the Drain plug on the lower back right side facing toward the passenger door.
Well I'm off to chevy to buy 3 quarts. Whata mistaka to maka. Hope I didn't screw it up?
Here's a DIY which I found very misleading. It makes one believe the tranny and differential are the same. Check where it shows the drain plug for the tranny is.....https://www.corvetteforum.com/how-to...mission-368419
That is so messed up!!! Entitled how to change the tranny fluid but then proceeds to show you how to do both tranny and diff without telling you the difference between tranny and diff. It never clearly showed where the tranny drain plug was. Figure 4 shows relatively fresh Diff fluid draining and then Figure 5 showing Tranny fluid being pumped into the Tranny Fill port. This DIY is an Epic Fail.
