staggered wheels
Old Aug 23, 2015 | 11:44 AM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Default staggered wheels
I want to put 19" wheels all around on my 08 Z51 and I've been searching but cannot find what I want to read. I seem to find a lot of threads that say it can't be done but none that tell me why. I'm thinking computer settings must be the answer. Any info would be great. The issue with searches is that you need the correct wording and maybe I'm not getting the correct wording.
Old Aug 23, 2015 | 02:11 PM
timd38's Avatar
timd38
Who says you can't do that? You can as long as the tires height is almost the same as stock. the wheel diameter doesn't matter, the tire diameter does.
Old Aug 23, 2015 | 05:55 PM
ls1121's Avatar
ls1121
so what parameters must I follow?
Old Aug 23, 2015 | 09:04 PM
RicK T's Avatar
RicK T
You need to maintain the correct front/rear ratio that the computer is looking for in order to avoid AH issues.
Once you find the front tire size you think you want, multiply the diameter of that front tire by 1.04 to get the desired rear tire diameter. I don't remember how much plus/minus you are allowed with that ratio but it isn't a large difference.
Old Aug 23, 2015 | 09:10 PM
ls1121's Avatar
ls1121
So it is sounding like no one has done this?
Old Aug 23, 2015 | 09:39 PM
87SAM's Avatar
87SAM
Many folks do this!
Old Aug 23, 2015 | 11:00 PM
timd38's Avatar
timd38
I have done, but with 18". Same principle. My goal was always to try to match up the height of the tires back to stock, so that the computer doesn't care.
Old Aug 24, 2015 | 07:59 PM
ls1121's Avatar
ls1121
I have a second set of 19" wheels and was wondering how to put these on the front, what size tires. My front 18" are a little chipped up.
Old Aug 24, 2015 | 08:05 PM
SG4206's Avatar
SG4206
On 19x10" wheels all around ; I'm running 275/30/19 on front - 285/35/19 on the back of my '10 GS.
Old Aug 24, 2015 | 10:17 PM
timd38's Avatar
timd38
Go to a tire website like the TireRack and see the height of the stock front and rears and then find 19" versions that are the same height.
Old Aug 24, 2015 | 10:38 PM
ls1121's Avatar
ls1121
OK thanx I will check that out.
To staggered wheels
