Ideas for retrieving DRL bulb
Old Aug 25, 2015 | 01:32 PM
Jack Boelte's Avatar
Jack Boelte
Default Ideas for retrieving DRL bulb
I was changing my DRL bulb, didn't have it secured in the socket fully and it dropped into the lens cavity. I can touch it with my finger and move it around. I wasn't able to get it with my flexible parts grabber. I don't think there's any steel on the bulb... This morning I thought about maybe trying to vacuum it out. Any ideas?
Old Aug 25, 2015 | 03:23 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Some double sided tape/chewing gum/poster hanging putty on a stick may work.
Old Aug 25, 2015 | 04:32 PM
05millenium's Avatar
05millenium
Cruising
Just had this happen to me about a month ago.
After cussing at myself for about 20 minutes, i tried many things, but what worked in the end was rubbing some glue on my finger and poking around in there to get it to stick to my finger.. Took a bit for the glue to get sticky enough..and seriously did not think it would work at the beginning.. but after about a half hour fiddling around i somehow snuck it back out the hole.
I believe the glue i had handy at the time was Gorilla glue.
Good luck.
Old Aug 26, 2015 | 09:55 AM
vette6500's Avatar
vette6500
Use a shortened telescoping magnet to fish around, it'll catch one of the two thin wire that wraps around the plastic end. Make it grab it at the end/edge and it'll lead it back out.
It'll continue to drop out and require repeated frustrations so you must bend the wires of the bulb OUT and it'll "pop" into socket more securely.
Old Aug 26, 2015 | 12:52 PM
R_W's Avatar
R_W
I use something like this around the garage:
Amazon.com: Flexible Claw Pick Up Tool Automotive Mechanic Shop 24 Amazon.com: Flexible Claw Pick Up Tool Automotive Mechanic Shop 24"
Cheap, and helpful when you drop things into hard-to-reach places.
Old Aug 26, 2015 | 01:47 PM
timd38's Avatar
timd38
Same here!
Old Aug 28, 2015 | 11:45 PM
Jack Boelte
The one I have has a big magnet on the end. No joy.
I'll try the sticky finger trick.
Thanks!
To Ideas for retrieving DRL bulb
