If memory serves me right. Two screws and the pry it off. The pins will sound like they are breaking, but if they do, the are easy to replace. The two screws are in the pocket area.
it looks like I have a problem with my driver side window, any tips or tricks or pics. on removing it what tools did you use? Thank you!
There's a cover behind the door handle I believe. Two screws behind that
Then it's just a bunch of plastic pop apart things. I take a plastic pry tool, start at the bottom of the door and get it to pop out.. work around the door. It will sound like the clips are breaking when you pop them loose. That is normal.. don't worry about it.
