C6 headlight sealed?
Old Sep 9, 2015 | 06:37 PM
Sayfoo's Avatar
Sayfoo
Default C6 headlight sealed?
I've read here that the headlight assembly is sealed--mostly.
The problem I'm having is that after the light has been r&r'd for front body work and paint, I'm looking at what appears to be a lot of dust inside.
So, if when it was removed and the harness/lamps were removed, and it was set aside in a dusty body shop, could it have gotten dust inside?
I read that there is a vent, but I'm assuming that it is pretty small and probably not the problem.
Thanks in advance
Old Sep 9, 2015 | 06:39 PM
timd38's Avatar
timd38
RLsebring would be your answer guy.
Old Sep 10, 2015 | 12:55 PM
Sayfoo's Avatar
Sayfoo
Yes, I'm trying to contact him.
Anyone else?
Old Sep 11, 2015 | 07:37 AM
Jtaugner's Avatar
Jtaugner
It's possible. Especially if they didn't leave the bulbs in.
You can try getting a air duster and blow it out the bulb holes, worse comes to worse you can pull the lens off and then re-seal them.
To C6 headlight sealed?
