Lowering C6
Old Sep 12, 2015 | 12:51 PM
ATMC6GS's Avatar
ATMC6GS
Navigator
Default Lowering C6
I turned the stock lowering bolts in rear counterclockwise and it actually raised the rear end not lower. What is right way to lower?
Old Sep 12, 2015 | 05:48 PM
t.renz791's Avatar
t.renz791
Call me crazy, but why not try the opposite way?
Old Sep 12, 2015 | 09:51 PM
RicardoFors68's Avatar
RicardoFors68
Did you see the pads at the bottom of the bolts getting closer to the spring? Also even after you crank those bolts to the max, the car won't settle down until you drive it a few miles.
Old Sep 13, 2015 | 10:23 AM
emoFTW's Avatar
emoFTW
You need to drive it around, but counter clockwise is the correct way.
Old Sep 13, 2015 | 05:10 PM
jovette's Avatar
jovette
to lower, screw the bolts in so that the pad side gets shorter to lower your car......
Old Sep 19, 2015 | 12:57 AM
C6David's Avatar
C6David
When you lift the car off the ground the car with sit higher when you put it back on the ground. Go for a spin and the car will settle down.
Old Sep 19, 2015 | 10:27 AM
ATMC6GS's Avatar
ATMC6GS
Navigator
Counterclockwise is correct, spring needs to settle after lifting, thanks.
Old Sep 19, 2015 | 10:28 AM
ATMC6GS's Avatar
ATMC6GS
Navigator
That works, thanks for your response.
Old Sep 19, 2015 | 10:29 AM
ATMC6GS's Avatar
ATMC6GS
Navigator
Perfect, thanks.
To Lowering C6
