Header Debable! Need input.
Old Oct 28, 2015 | 09:41 PM
extrapilot's Avatar
extrapilot
Originally Posted by schpenxel
The shifter boot was leaking on mine.. Previous owner did a bad job cutting the boot when installing the mgw shifter so it was a pretty big leak right from under the car
What I was going to post also, since this issue has come up here before.
Old Oct 28, 2015 | 09:55 PM
mchicia1's Avatar
mchicia1
Originally Posted by Joe_G
Even with no cats, you shouldn't smell exhaust while driving. I don't smell anything idling either and I have a big cam - it'll make your eyes water if you stand behind the car, especially on a cold start, but that doesn't get into the car with the windows up.
Something else is going on.
I'd look into that rear hatch seal. I'm thinking you have a leak somewhere either in the exhaust or at the rear of the car. Exhaust leaks at joints manifest themselves by soot at the seams as well...look for that up on top as well. Your storage cubbies weren't cut out were they? A smoke machine would help in this analysis if you have one at your disposal...
I'm drawing a blank on location, or if I'm getting my cars confused, but isn't there a port on the rear pan with a flap on it, to allow air out when you shut the hatch...if that flap is missing for some reason, it'll let air back in that shouldn't get back in if my memory is correct...
Thanks, we will check that!
One thing to note as well is that even with his bone stock exhaust on, you would get an odor in the car after going wot even at high speeds. It wasn't nearly as bad as this odor, but I think it indicates the car has an issue sealing exhaust gasses out of it.
Old Oct 28, 2015 | 10:01 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You've got a hole somewhere in your rear hatch area. Was the car ever wrecked? That tub in the back is a big one piece tub so it shouldn't leak unless the seal is broken or there's a hole in it as I posted.
Stock manifolds and cats will produce stink when you go WOT and it hits open loop 11.5 afr. You've smelled this from cars in front of you if they get on it.
You should never smell this in the car from your own car so you've got something going on there. I don't think the shifter boot will do it unless you've got a major leak at the header collector... which you must not have or you wouldn't have gotten it tuned so tight...a collector leak wreaks havoc trying to tune idle and part throttle.
Old Oct 28, 2015 | 10:04 PM
mchicia1's Avatar
mchicia1
Ya I agree, it has to be coming into the trunk area.
Yeah both 02s were switching well, so not indicative of a leak around that area. Plus they are ball->flange connections, which generally do not leak.
Old Oct 28, 2015 | 10:06 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You're right about that, American Racing uses the best collector connections in the business. I love those connectors, it makes any maintenance on the car so easy...unlike some other connector designs.
Old Oct 29, 2015 | 11:11 AM
echelonphoto's Avatar
echelonphoto
Thanks guys...keep them coming...if I can at least keep the smell out of the interior, I can live with it for a while.
Old Oct 31, 2015 | 11:49 AM
echelonphoto
Well....I checked all my hatch seals and treated them with the gm stuff. Also temporarily plugged up the 4 drainage ports around the hatch. Still coming into car with windows open any amount. If I close the windows and run recirc. it is better. However, there is always a puff of smell coming in on every startup...even with the windows closed....
Old Oct 31, 2015 | 11:51 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Do you have access to a smoke machine? Matter of fact, I saw some at Party City for Halloween...I'd suggest you get one and fill the car with smoke and see where it starts coming out...you might need to turn the air on low and outside air to get it to start coming out...
You've either got a massive exhaust leak before the mufflers or a hole in your car somewhere.
Old Oct 31, 2015 | 11:58 AM
echelonphoto
That might be a clue
