Akebono ceramic pads
Old Sep 25, 2015 | 12:42 PM
da6speed's Avatar
da6speed
Default Akebono ceramic pads
I've searched here for a good performing low dust pad and these keep popping up.. BUT everything I read says not to run ceramics on the "track"...
Is the track referred to a road coarse?
My car sees road duty and dragstrip some, no road course here, so would these be ok for me?
Old Sep 25, 2015 | 04:23 PM
RicK T's Avatar
RicK T
Yes the "track" referred to is road course, even HPDE in some cases. And yes these will work for your stated use.
The problem with ceramics is they fade pretty quickly when they get hot.....generally from repeated application from high speeds. Slowing down once after a drag strip pass should be no problem.
Old Sep 25, 2015 | 07:31 PM
da6speed's Avatar
da6speed
Ok thanks!
Old Sep 25, 2015 | 10:39 PM
KW Baraka's Avatar
KW Baraka
Akebono = top shelf pads.
I used to run these on my CLS 550......great for 'spirited' driving on the street.....and for daily stop-and-go driving as well.
If these pads were available for my SS......I'd be using them on that car, too.
KW
Old Sep 27, 2015 | 01:17 AM
Torquem's Avatar
Torquem
Yeah I called Akebono yesterday to see if I could source some ceramics for my grand sport. Unfortunately they do not make them yet but said they have plans to.
I'm not happy with the performance of my Carbotech 1521 pads.
Old Sep 27, 2015 | 01:40 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Please elaborate on your issue with the 1521.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Sep 27, 2015 | 02:39 AM
Torquem's Avatar
Torquem
They are too soft for my taste and don't do very well wet, which I could live with. But the main thing is the loud groaning upon initial bite/release. I made a phone call to Carbotech and they admitted that its just something they do and recommended braking harder It drives me nuts especially for what they cost. So they will be coming off as soon as I can find a suitable replacement.
Old Sep 28, 2015 | 02:13 PM
RC4G's Avatar
RC4G
You might consider the Duralast Gold Ceramic pads (I sourced from Autozone for my 2012 Grandsport)?
$106 total for front and rear pads.
Brake dust is now non-existent compared to the OEM semi-metallic and no more brake squeal.
Old Oct 2, 2015 | 11:37 AM
deadsexyii's Avatar
deadsexyii
Akebono pads is one of the best things I've done. No more squealing, no more brake dust. 09 Z51
To Akebono ceramic pads
