Steering wheel play
Old Oct 3, 2015 | 12:28 AM
JD McC's Avatar
JD McC
Default Steering wheel play
2011 GS. Developed excess play in the steering wheel, about 1 inch each direction. Problem is in the column. Ruled out the tie rod ends, rack,intermediate shaft. What is probably the problem and how hard would it be to fix? Drives me nuts on the highway and in autocross slaloms.
Old Oct 3, 2015 | 02:42 AM
loco_stevie's Avatar
loco_stevie
If you don't mind me asking, how did you rule out everything? If what you are saying is true, it'll be tough to answer this question!
Old Oct 3, 2015 | 10:44 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'm wondering how everything was ruled out too.
Old Oct 3, 2015 | 02:07 PM
CrvtBB's Avatar
CrvtBB
Veteran: Coast Guard
my guess is you might need to have the steering rack replaced. I had a similar symptom develop shortly after I purchased my '11 GS and they did something with the column first, which didn't fix it and finally ended up having to replace the rack. Been fine since.
Old Oct 3, 2015 | 04:31 PM
JD McC's Avatar
JD McC
Had it up on rack with a mechanic. Examined the tie rod ends, replaced the rack (x2). If you watch the intermediate shaft while turning the steering wheel, the shaft does not move while the steering wheel is moved within the area of play. Thought it might have been in the upper U-joint of the intermediate shaft so I was going to replace the intermediate shaft, but I noticed that the play in the steering occurs before this joint as well by observing where the column shaft meets the intermediate shaft. So, the play in the steering occurs before the intermediate shaft. Has to be in the column as far as I can tell.
Old Oct 3, 2015 | 04:49 PM
ChevyDave's Avatar
ChevyDave
that much play above #51 seems pretty scary to me! (fyi.. this is a telescoping column parts list)
Last edited by ChevyDave; Oct 3, 2015 at 05:31 PM. Reason: addd note that this is telescoping version
Old Oct 3, 2015 | 07:29 PM
loco_stevie
That's what I was trying to say, if OP already eliminated those possibilities, I can't think of known items on the vette that will cause 1" of play in both directions...
I wish I can help more, but if you ever find out, please let us know!!
Old Oct 4, 2015 | 04:45 PM
Dano523's Avatar
Dano523
Ditto with ChevyDave,
Lock out the connection to the gear pinnon rack just below #51 so the gear rack connection is not able to move, then see how much slop you have in the steering column from there back at the steering wheel itself.
To Steering wheel play
