New guy, suspension? probelm
Old Oct 7, 2015 | 08:21 PM
Cole Crockett's Avatar
Cole Crockett
2nd Gear
Default New guy, suspension? probelm
Just traded my boat for an 08 today. Discover a problem this evening. On full lock left turns (slow speed) there is rather loud clicking noise from the right front wheel area. I can only describe it as sounding like a bad CV joint/axle, which obviously it is not. Any ideas?
Old Oct 7, 2015 | 08:34 PM
EVRose's Avatar
EVRose
Do a search for tire scrubbing. It happens because of the width of the tires trying to make two different radias turns at the same time. Its considered normal on these cars.
Old Oct 8, 2015 | 07:35 PM
SG4206's Avatar
SG4206
Might also be an end link worn out on the sway bar.
Old Oct 8, 2015 | 08:12 PM
Curt D's Avatar
Curt D
How many miles? Are you 100% certain it is the front? I had to have somebody listen for mine...which ended up being in the rear of the car
Old Oct 8, 2015 | 08:48 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Is it click, click, click or just one "clunk"?
Old Oct 9, 2015 | 01:16 AM
rpmextra's Avatar
rpmextra
there is a TSB on the rear axle nut torque. double check that they are indeed torqued to 151ft and if they were loose, replace bolts, use loctite and retorque to 151ft
To New guy, suspension? probelm
