NPP Question
Old Oct 10, 2015 | 11:23 AM
Kingman99's Avatar
Kingman99
Default NPP Question
Hi
I have a 2007 vert and would like to have a more aggressive sound! Right now l am spending a lot of $ on my house so an exhaust system is out of the question.
I have heard good things about the NPP system but no clue on what l would need to accomplish this. Plus the approx cost and approx cost to revert it back to stock the right way and not a patch job.
Alan
Old Oct 10, 2015 | 11:44 AM
RicK T's Avatar
RicK T
2 NPP mufflers.....anywhere from about $600 - $1000 used.
1 "NPP in a Box" kit (there are at least 2 kinds) to supply vacuum and control...$150 - $200.
Someone to install....cost varies widely....I would guess $150 - $250 (unless you can do it).
The caveat is NPP model years. If you can find a set from an '08, they will bolt right in.
But GM changed the passenger side over axle pipe slightly in '09 so anything from '09 up will not bolt straight in. A good exhaust shop can make it work by bending your car's x-pipe or making an adapter of some kind, probably not what you would want.
So if you find an '09 or newer NPP set, the best thing to do would be to also buy the accompanying '09+ x-pipe or buy a new one from GM. I don't know what they cost from GM.
Old Oct 10, 2015 | 11:45 AM
hippy's Avatar
hippy
For $850 I have a FULL Z06 exhaust on my car. Manifolds, cat pipes, H pipe, bi mode mufflers, 3 way solenoid, remote switch, check valve, and vacuum lines, which make the bi mode fully operational from my homelink visor. Not only does it sound a ton better than the stock exhaust (I have modded mufflers) it is probably worth 25-30rwhp over stock being the full Z06 exhaust.
Old Oct 10, 2015 | 01:24 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I've got about $700 in mine.
That is Z06 headers, Z06 cats, H pipe and modded Z06 NPP mufflers. Basically, a full 3" Z06 exhaust system from engine to tips.. I just ran the vacuum controlled valves on the mufflers directly to a vacuum source. They open about the right time.. you don't have control over it this way, but it is simple and has worked really well for me.
Several vendors have piles of these laying around from doing header/exhaust installs
Base 2007's have a 2.5" system, the Z06 stuff is 3".. so that's why I did it all. I think there's a 2.5" version of the NPP version but I can't remember what it's used on
Old Oct 10, 2015 | 04:25 PM
Kingman99's Avatar
Kingman99
Thanks for the feed back
Alan
Old Oct 10, 2015 | 04:55 PM
ssmike56's Avatar
ssmike56
I just did an NPP retrofit on my '06. I found a pair of low mileage NPP mufflers off of an '08 (direct fit) on Craigslist for $275. I paid $150 to have the stockers removed and these installed. I then purchased the "NPP in a Box" kit which gives you the vacuum lines, tap, and wireless controller for $180 from a vendor here on the forums. It took me about 2 hours to install the NPP in a Box. Total cost was $605 and well worth it!
Old Oct 10, 2015 | 05:15 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Originally Posted by hippy
For $850 I have a FULL Z06 exhaust on my car...it is probably worth 25-30rwhp over stock being the full Z06 exhaust.
No, not really. Maybe 20HP going from a base exhaust to full Z06 exhaust. I got 14RWHP on my 2013 GS (which had NPP) when I did it, and that included eliminating the second set of cats that they added in 2012. It does sound good though, and even better if you gut the LS7 cats.
Old Oct 11, 2015 | 01:53 PM
hippy's Avatar
hippy
I have an LS2. I did that exhaust, 1.8 rockers and home ported the intake and got 402 rwhp. I got 50ish somewhere, 10 from the intake 15 from the rockers leaves around 25. Someone else on here posted they pulled 30 just from the exhaust so I think on a LS2 that 25-30 is quite doable.
I don't know if you have modded mufflers but if you don't that IMO really makes a big difference. I have a set of both mufflers (stock and modded) and the modded ones sound much better than the stock Bi Mode muffers.
Old Oct 11, 2015 | 03:32 PM
EvanZR1's Avatar
EvanZR1
Nevermind, I completely missed the LS2 part, they will make more difference there than on an LS3.
Old Oct 29, 2015 | 12:21 AM
Dcasole's Avatar
Dcasole
Hey Allan,I live close to you
You are welcome to stop by and listen to my NPP if you like
PM me
Dave
Old Oct 29, 2015 | 05:50 AM
cuspid's Avatar
cuspid
I bought a set of npp's that are 2.5 inch, the seller claimed they were from a 2010 gs. I hope they are a direct bolt on for my base 2013. Is there any point in hooking up the vacuum because either you will have them open all the time or closed
Old Oct 29, 2015 | 07:44 AM
Dcasole's Avatar
Dcasole
Yes they will fit , it's a direct bolt on .
Most of the time I ride with my NPP'S open but there are times when I want i quiet. On the highway they can drone .
Different people have different opinions on what is tolerable and what is not .
It is nice to have the option
Dave
Old Oct 29, 2015 | 08:56 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I have the Z06 setup and when they are open it does drone a bit at lower RPM's, particularly at 60-65mph on the interstate it can be quite annoying. Before I connected them to a vacuum source I just used 5th instead of 6th on the interstate and that was significantly better.
Mine are just hooked straight to a vacuum source. They "open" around -2.5psi on the "boost" scale which works out about right IMO.
Old Oct 29, 2015 | 11:39 AM
jrose7004's Avatar
jrose7004
I have $850.00 in a used set of Corsa Sports so for that kind of money you can basically get whatever you want.
Old Oct 29, 2015 | 03:14 PM
Kent1999's Avatar
Kent1999
If you watch the forum F/S section and on eb*y, very often you can pick up a used C6 perf exhaust system for less than $500 that will bolt right on with no other costs and a minimal amount of work.
Clearly, the NPP is a good system, but if you're looking for something low-cost, there are cheaper options than hoping to luck into a cheap 2008-only NPP set and also an NPP controller.
To NPP Question
