Widen 18x10.5 to 11.5 Rim,tire size
Id really like too get the 345 MT drag radial im just concerned with the rear inner clearance after the 18s are widened. Any opinions Gents?
I use a O.E. Wheel 9.5" rim with a starting offset of 54-56mm will allows 2" addition and still clear on the inside. I run a 335x35x17 Kumho 710.
https://www.corvetteforum.com/forums...post1578047054
--Dan
In my experience with 17" wheels I had to start with a replica 9.5" wheel to end up with the correct offset after widening on a base model -- which it looks like you have. All width is added to the backside. 10.5" wheels that I found did not have the offset necessary to fit under the fenders even before widening.
--Dan
--Dan
Much will depend on the height of the MT drag tire and if you're lowered. For autox/track we run camber which tucks the top of the tire in which I doubt you will do. My race tires are shorter than OEM.
Mock up some cardboard in your tire diameter and test it.
--Dan
Typical 10.5" wheel has a 58mm offset. This puts the outside edge at 3.5" from the hub. Your OEM 19x10" wheel is out 2.4" -- so one more inch to the outside. Many folks run the 10.5" square setup but I believe they use smaller tires like a 315 max. In any case, your can add 1" to the inside of the 10.5 and that will fit.
--Dan
--Dan
Only problem with widening a 17x9.5 to a 11.5 is a arm clearance when the suspension is fully extended. I got my 17x9.5 oewheels widened to 17x11 to fit my 315s in the base model fenders and they almost touched the upper a arms. With the car being stock height it wouldnt hurt to start with the 10.5 but the wheel will stick out of the fender.
This is the clearance I was talking about. This is with the 9.5" wheel. I wanted to widen them to a 17x11.5 but it just wouldnt clear it. Other pic is the wheels after widening. Then them on the car. 315/35/17 hoosiers. If you wanted to run a narrower tire you could go with a 305/45/17 et street r on a 17x10.5. I was spraying a 200 shot out of the hole on the track. On the street had it coming on at 3500 dead hooking on the hit. Doesnt spin in first gear. Which is what I have in the last pic.
--Dan
--Dan
Received 2,061 Likes
Not trying to be a SA, but 600 on a 150 shot doesn't need anything more than 275/40x17 Dr's to hook. You can do that on a 9.5 wide x 17 wheel.
What 60' times are you getting now and with what tires?
That is kinda why I asked. I personally think a 275 is a bit small but I'm in the 600-620ish range and my 315 on a 9.5" 17 hooks hard. Best 60ft so far is a 1.46. I consistently hit 1.50 almost every launch. if I had some gear I'd do way better
He'd need to run 315's with lower pressure than 275's to have an advantage if he sprayed on the launch, so he better have more hp to carry him through the traps. I'm 1.48-1.50 with a whole lot less power on 275's at 18-19 psi on a 9.5 x 17.
If you're hooking hard, you need to either launch harder or raise pressure.
I assumed he would launch with 450 hp and the 275's would easily handle that. Then after he's rolling, he'd hit the spray.
It's OK to want to look like a fast car, rather than be one. Just don't expect to perform like one without the right stuff.
Actually 50/50 i was just at Street Car Takeover and my 285 street tires were practically worthless. Street rolls was practically all i could perform with on behalf of my crap launches. Looking for both pal, if i can get a 2nd set of rear wheels too throw on for track it be nice too have a 10 sec Vette as my Dailey but cant do that with current tires.
