Windshield Washer not working
Old Nov 3, 2015 | 05:12 PM
rhoyvald's Avatar
rhoyvald
Default Windshield Washer not working
I have a 2005 z51 vert and the windshield washer is not working. The wipers are fine but the pump wasn't working so I removed the pump and decided to test the pump off the car and it started right up when I hooked 12V to it.
So the question is there a fuse that is just for the pump? I guess the next step is to hook a voltmeter to the pump's plug and hit the washer button.
Anything other thoughts and/or insights?
Thanks!!!!
Old Nov 3, 2015 | 08:54 PM
WhiteDiamond's Avatar
WhiteDiamond
St. Jude Donor '15
My wipers on my 2007 stopped working and it was the fuse for the washer pump that was blown. Replaced the fuse and the wipers started working. Wonder if you could have the reverse. Maybe your wiper motor fuse is blown and not allowing the washer pump to work.
Old Nov 4, 2015 | 03:23 AM
Dano523's Avatar
Dano523
Start with the wiper pump fuse in the engine fuse box to make sure it not blown, and if it still good, then suspect that the switch stock assembly in the steering column needs to fix/replaced instead.
Old Nov 4, 2015 | 08:16 AM
rhoyvald's Avatar
rhoyvald
Will do and thank you for your advise!
To Windshield Washer not working
