Edelbrock Cross Ram
I called Vararam about their new fancy intake manifold and they said it will be for sale in January. They claim it has made substantial and real gains over the OEM LS3 intake.
If Vararam's claims turn out to be true (unlike the Power Wedge claims) I'm 100% a buyer.
http://www.ozmoengineering.com/produ...-tb-controller
The OZMO Engineering Twin Throttle Body (TTB) Controller is an electronic control unit designed to facilitate running a secondary throttle body on off-road engine applications. The TTB controller will read the signal from a “master” throttle body throttle position sensors and drive a “slave” throttle body to the exact same throttle position.
Positioning of the slave throttle body is accomplished through Proportional, Integral and Derivative (PID) control. This allows the controller to be used for any manufacturer throttle bodies that use 5V throttle position signals. Motor frequency can also be controlled to match the OEM specifications of the throttle body.
The controller will “read” the voltage signals from the master throttle body, but will not draw current. This means that the ECU driving the master throttle body will not “see” the OZMO TTB controller or the slave throttle body. As such, all signals sent to the master throttle body by the ECU (e.g. cruise control, traction control etc.) will be mimicked by the slave throttle body.
Safety features of the controller include:
• Error count when slave throttle body is >5% out of position
• Shutdown of slave throttle body if error count reaches 100errors
• Degradation of error count over time
• Output ground signal for shutdown indicator or ECU integration (fail safe)
• Over voltage protection
Note that this controller is designed for non-vehicular engine use only. As engine throttle control is an important part of engine function, it is recommended to fully test the user installed wiring and functionality in all environments in a stationary engine application.
MSD LS3 intake made a great deal of hype, then it never came out. I think we will see it, but not sure how many will see gains using it.
It does look cool!
There are a LOT of people that can utilize the amount of air it will flow. The number of 400+ cubic inch engines with LS3 heads is pretty damn high. Especially given that they have large cams and will spin to 7500 IF there is intake airflow to support it.
that is exactly why my company is doing R&D to bring a DBW 4150 and 4500 throttle body to market. The number of people that would switch to a large single plane if such a throttle body were available is rather high.
