Crank Pulley removal
Old Nov 5, 2015 | 11:21 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
We gotta have something to complain about
Old Nov 5, 2015 | 05:57 PM
ttx350z's Avatar
ttx350z
Originally Posted by schpenxel
I put mine in 6th I believe it was, had someone hold down the brake (e-brake may work, not 100% sure) and that worked. There was a little slack you had to take out when you were turning the balancer bolt at first, but not a huge amount
The flywheel holding tool is probably a safer bet, though.
I used 6th and parking brake. Once the drivetrain slack was taken up, it held no problem with the rear wheels off the ground.
Old Nov 5, 2015 | 06:34 PM
UmX's Avatar
UmX
ill have rear on the ground im sure anyways.. just gonna lift the front end..
Old Nov 5, 2015 | 07:44 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Should work fine. Just don't let it roll over you
Old Nov 5, 2015 | 08:33 PM
ttx350z's Avatar
ttx350z
Yep that's why I put the rear on jackstands. Didn't want to try it for the first time and have the car roll off the front jackstands.
Old Nov 5, 2015 | 08:35 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Might just be my tall jack stands, but the front was too high without raising the rear for me to work comfortably, but no reason it won't work.
Old Mar 2, 2016 | 05:05 PM
UmX's Avatar
UmX
so im going to start this project soon. Im going to pull the rack... can the radiator stay hooked up
Old Mar 2, 2016 | 05:37 PM
ttx350z's Avatar
ttx350z
Yes, I did remove the fan since it is easy to get a little more room for an impact wrench to remove the crank bolt.
Old Mar 2, 2016 | 06:17 PM
UmX's Avatar
UmX
ok cool. ill see what i am getting into when i am in there.. really dont want to deal with draining the coolant again lol..
Old Mar 2, 2016 | 06:19 PM
rjacobs's Avatar
rjacobs
take a small torch to the crank pulley bolt and get it hot. there is a sealant(not lock tite, think red RTV) on the back side that doesnt like to let go of the crank snout. 4' breaker bar wouldnt budge it so I got out the 450ft. lbs. impact and that wouldnt budge it until I heated it up, then it came off no problem.
Old Mar 2, 2016 | 07:11 PM
UmX's Avatar
UmX
well dam lol.. hopefully mine wont be that hard.. only been on for like 1000 miles lol but ill remember the heat trick
Old Mar 2, 2016 | 09:39 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Long pipe on a breaker bar and you'll be fine
Old Mar 5, 2016 | 05:37 PM
  #33
UmX's Avatar
UmX
Can u pull power steering rack out driver side? I have way more room on that side in my garage to work
Old Mar 5, 2016 | 09:21 PM
  #34
rjacobs's Avatar
rjacobs
I dont believe you can without dropping the cradle. And I dont even think it will come out the passenger side without dropping the cradle either(maybe with a lot of cussing and banging you can). The actual steering gear on the drivers side of the rack is in the way of going out the small hole. You can maneuver it out the passenger side far enough to work with the pulley.
Old Mar 5, 2016 | 10:27 PM
  #35
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It wil come out the drivers side. Last time I did it the cradle may have been lowered a little bit, but it would have only been an inch or so at most. The PITA is from the brake lines and the ABS pump being right in the way..
The easiest way (IMO) is to push it towards the passenger side. It won't come out that way, but it will get out of the way enough for you to do whatever you want. I did it that way when I changed the cam on mine.
Old Mar 5, 2016 | 11:15 PM
  #36
Brandon619's Avatar
Brandon619
This is exactly the way I did it, as you can see in my last cam swap.
Old Mar 6, 2016 | 08:48 AM
  #37
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yep! Same on mine, except I went dowel'less
Old Mar 6, 2016 | 01:55 PM
  #38
WW7's Avatar
WW7
The video says to drop the cradle 1/2" to get the rack to come out the drivers side..There are a couple good videos on "YouTube" showing how to do the job .....WW
