Detonation fix?
Old Nov 7, 2015 | 10:11 PM
Southmsfiveo's Avatar
Southmsfiveo
Default Detonation fix?
'06 LS2 75,000 miles stock except for Vararam CAI and SLP Loudmouth II mufflers. Premium only. Chevron. A bottle of Techron once a month.
I thought it was a heat shield rattle but it turns out to be detonation on moderate to heavy acceleration (3000-3500rpms and up). A little sputter with the noise.
Someone suggested new plugs and a tune (custom tune) will resolve the issue and get a performance boost.
Open to any and all suggestions?
Old Nov 7, 2015 | 10:32 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Are you logging and actually seeing knock or just feeling/hearing it or what exactly? Factory original tune?
If you're seeing it on logs I'd replace knock sensors just to be sure it's not those. Don't over torque them when you install the new ones (I think the spec is 18 ft lbs). It's a long shot, but they're cheap and easy to replace, so you might as well be sure they're good first
New plugs aren't a bad idea
It shouldn't keep knocking regardless, though. The way the factory computer works is after it sees a certain amount of knock it biases towards the low octane timing table. It takes quite a while for it to slowly work its way back to the high octane timing table.. so if it knocks a few times it really should be pulling the timing down far enough that it shouldn't keep doing it. That's why I ask if you're actually seeing it on logs or just think you hear/feel it.
Need more details before I can say much else. I fought false knock on mine for months. Found water pump bearings were going out, power steering bump bearings were going, alternator bearings were going.. all set the knock sensors off like crazy.
Old Nov 8, 2015 | 01:04 AM
Southmsfiveo
Thank you schpenxel! I will start data logging in the morning and through out the week. I will update the op. It seems to me it ll relates to the recent install of CAI and mufflers.
Old Nov 8, 2015 | 08:36 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Do you have hp tuners or what?
Old Nov 8, 2015 | 02:11 PM
Southmsfiveo
No sir. All stock other than the CAI and mufflers.
Old Nov 8, 2015 | 05:40 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Then how are you data logging?
Old Nov 8, 2015 | 06:17 PM
dennis50nj's Avatar
dennis50nj
Old Nov 8, 2015 | 06:45 PM
Southmsfiveo
I have assumed my Innova diagnostic tool that collects "live data" was the same as "data logging." If not then I am not data logging.
So I have looked at the Innova website. I don't think this device does nearly the job that HP Tunes. I also look at the HP Tunes site. It seems to me that getting HP Tune or similar product to data log (est. $400) and then have a tune developed for my specific vehicle and circumstances another couple of hundred dollars. But will it resolve the issue?
Last edited by Southmsfiveo; Nov 8, 2015 at 10:34 PM. Reason: More information to share
Old Nov 9, 2015 | 07:23 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
If the issue is your exhaust hitting the body or suspension, no HP Tuners can't fix that. Your car will pull timing to prevent knock before you actually hear it so it's odd that you would actually hear knock.
I'm suspecting that your mufflers are hitting, I'd suggest you get it on a lift and scope that out carefully - if you can do a drive on lift that's a lot better as it'll show you where things are sitting when the car is on its tires. That's what I'd do before I spent a lot of money on anything else.
Old Nov 9, 2015 | 08:11 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Agreed... I've heard the heat shields on my manifolds creak before and saw the knock retard go nuts.. so it does not take much at all
Old Nov 9, 2015 | 09:44 PM
Southmsfiveo
It's not the exhaust or heat shields. I have my own lift and have checked everything.
To Detonation fix?
