squeaking ls7 help!
Old Nov 10, 2015 | 06:14 PM
Ajsegal's Avatar
Ajsegal
Default squeaking ls7 help!
Hello all,
hoping some of you guys could help me out. I have a squeaking coming from engine bay. Thinking it may be a pulley or bad bearings. I'll post a video let me know what you think or what I should check. Any help is appreciated! 2008 z06
Watch "Z06" on YouTube
https://youtu.be/NPTZ8hXH59Y
Old Nov 10, 2015 | 11:13 PM
rpmextra's Avatar
rpmextra
you can use a little chalk (tire stick) and let the belt rub it on the rib side (watch your fingers. As the belt wears into the chalk, it will coat itself. it the sound disappears its the belt itself. If not, I can not tell direction listening to a video but look into your ac and drive tensioners too. I have also heard alternators make noise like that. You can pull the belt ad free spin everything to see if you can duplicate it and narrow it down.
Old Nov 10, 2015 | 11:50 PM
Ajsegal's Avatar
Ajsegal
Thank you sir, I will try that tomorrow.
Old Nov 11, 2015 | 01:58 AM
Dano523's Avatar
Dano523
Need to chase it down a little farther, but does sound like a dry bearing in either the idler or tension pulleys.
https://www.corvetteforum.com/forums...er-broken.html
Old Nov 14, 2015 | 11:30 PM
Ajsegal's Avatar
Ajsegal
It ended up being the belt luckily.
Old Nov 15, 2015 | 09:08 PM
rpmextra's Avatar
rpmextra
good stuff
Old Nov 15, 2015 | 09:35 PM
rpmextra's Avatar
rpmextra
good stuff
To squeaking ls7 help!
