Pulling heads. Advice welcome!
Old Nov 20, 2015 | 12:07 AM
Ajsegal's Avatar
Ajsegal
Default Pulling heads. Advice welcome!
So I'm going to start my winter project of pulling heads on my 08z and sending them to WCCH to have them reworked . I'm honestly sick of worrying about the valves dropping everytime I drive it. I read over a lot DIY threads and videos, have a decent stash of tools, and like to think I'm pretty mechanically inclined, but have never done heads before. Anyone who has done this have any advice or tips? Also the car is Paxton supercharged. So does anyone know if the paxton head unit will need to be removed in order to pull heads?
Old Nov 20, 2015 | 08:09 PM
timd38's Avatar
timd38
Buy head studs to go with your supercharger!
Old Nov 20, 2015 | 10:37 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Yes you have to pull the entire front belt assembly off. The power steering reservoir bracket is the only pain in the butt. The rest is easy. Be sure and notch the power steering reservoir bracket so it goes on easier.
Check out this thread from Jaysplayss2 for a pic of how to notch that bracket. When you remove it you'll see what I'm talking about. You can only move the bolt 15 degrees or so. A ratcheting box end would probably help if it had very fine ratcheting detents.
https://www.corvetteforum.com/forums...s-of-pics.html
Old Nov 21, 2015 | 11:21 AM
Ajsegal's Avatar
Ajsegal
Thanks for the input guys. The heads are off. To be honest everything was pretty easy, didn't really get stuck on anything. There was a lot of coolant in the cylinders which I vacuumed up and like an idot I wiped down the cylinders with a clean shop wrag. I heard this is a no no because of the possibility of getting lint or debris stuck in the piston ring. Any truth to this or should I not be worried?
Old Nov 21, 2015 | 12:45 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I never heard that a rag is a problem. Wouldn't make sense to me. A scotch brite pad would be a problem I understand the shavings aren't friendly to bearings.
Old Nov 21, 2015 | 02:42 PM
JaimeVrod's Avatar
JaimeVrod
If that coolant made it into your oil, it could really mess up the viscosity of the oil. I would recommend an oil change right after you bolt everything back together, not before. Watch the oil pressure when you start the engine. If the pressure is erratic, shut down and do the oil change right away. If the pressure seems normal, run the engine a bit to get the coolant out between the piston rings, then change the oil.
When I changed the heads on my old Chevelle w SBC, I got coolant in the cylinders and when I restarted the car the oil pressure was bouncing al over the place. I remember someone telling me to add a quart of diesel to the oil to help soak up the water and coolant, which I did and ran the engine for a few minutes, then did an oil change. Everything was better after that.
Old Nov 24, 2015 | 08:25 PM
zulatr's Avatar
zulatr
getting coolant on the piston tops is unavoidable, and Iwould remove as quickly as possible, as I think you did. When I did my 08 Z heads and cam at the same time, I was concerned about the oil. I ran the engine to break in the cam, and then checked the oil, found it fine, then changed it for safety sake, and then watched the removed oil to see if it would separate out any water, which it did not, and it had zero milky tint to it. In my experience, no water got in the oil.
be smart, be careful, be aware, you have a very expensive engine, but don't be over concerned, rings are tight, coolant isn't draining past them like going down a sink drain. Like offered above, change the oil, but in my opinion, do it after you've had a chance to circulate it, otherwise you may end up with coolant not draining out.
To Pulling heads. Advice welcome!
