Dedicated fuel cell help
Old Nov 20, 2015 | 07:26 AM
curtisb23's Avatar
curtisb23
Default Dedicated fuel cell help
I've been to my tuner 3 times for a nitrous tune and every time my system is lean as hell can't even get a half of pull in to do anything. I have a nitrous outlet nitrous kit along with a c5 fuel cell for my c6. I'm running the cell on low psi I have a 78 fuel jet in it on 10 psi for a 225 shot and it's just crasy lean
Old Nov 20, 2015 | 06:42 PM
zemog255's Avatar
zemog255
Are you sure the fuel solenoid is working or even the pump on the fuel cell. As long as both of those are working. Short of having a bad ground/connection or crap in the lines. Im not sure what else it could be.
What all have you tried so far to solve the problem? That will help eliminate a few things or give you some ideas to try. I would start small on the shot size assuming you are using a nozzle or a plate. Trying a 225shot without having the system ironed out could end badly.
Old Nov 25, 2015 | 08:09 AM
curtisb23's Avatar
curtisb23
iv done smaller shots and its fine as soon i go to a big shot it acts up, i have a new regulater and pump for it now going to see if that fix it
To Dedicated fuel cell help
