Valve spring question
Old Nov 29, 2015 | 07:09 PM
Ajsegal's Avatar
Ajsegal
Default Valve spring question
Had my heads sent out to American heritage performance for there stage 4 package. Not really thinking I got the btr dual spring kit too. I have a stock cam with an ecs blower at 8psi. Are these springs ok to run with a stock cam? Or should I send the heads back and have stockers put in?
2008 z06
Thanks!
Old Nov 29, 2015 | 10:42 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Better valve springs are just that---BETTER------Longer life and valve train stability--Being you have a stock cam your engine would have been fine with the stockers as being supercharged has little affect on valve springs---Better valves are just a cheap insurance policy---
Old Nov 29, 2015 | 11:16 PM
Ajsegal's Avatar
Ajsegal
Thanks for your input, thats what i was thinking at the time of purchase. But....... I think I remember reading that stiffer springs with a stock cam can put a significant amount of stress on rockers,pushrods,cam, and lifters. More so that stock springs. Also read something about vavles closing to hard and bouncing with stiffer springs and stock cam. Ha, I'm probably over thinking it
Old Nov 30, 2015 | 01:06 AM
ELEFUNTMAN's Avatar
ELEFUNTMAN
Stiffer spring will hold the valve seated much better, and no "bounce". There may be more "stress", however with a mostly all roller valve train, I wouldn't worry about it.
Old Nov 30, 2015 | 10:09 AM
Ajsegal's Avatar
Ajsegal
Thanks for the input guys. I'm most likely going to keep them. I Want to talk to AH before I do anything
Old Nov 30, 2015 | 04:29 PM
gsflyer2011's Avatar
gsflyer2011
That write up was in one of the Corvette magazines quite a few months ago and also for me it was an eye opener. The stock valves did better with stock springs had lot less bounce if i recall correctly. You are not overthinking, your instincts may be correct. GM spent thousands of hours to make sure that the valve train was stable and to reduce the bounce on a closing. Go research those 2 magazines, it was either Corvette or Vette magazine.
Old Nov 30, 2015 | 08:16 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Personally, I would contact BTR
Old Nov 30, 2015 | 08:29 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I ran the BTR 660 springs with factory push rods, lifters, rockers & cam for a month or so without any issues.
Old Nov 30, 2015 | 09:15 PM
tblu92's Avatar
tblu92
If you even to more research you will find many many failures of STOCK LS6 valve springs on a STOCK cammed Z06----They don't hold up well under higher RPM running
or performance driving---Using weak stock valve springs to get more HP or avoid valve bounce is an old wife's tale---
Your supercharger will put more stress on your engine than anything else--Good valve springs will insure the valves will close properly and not allow boost to enter the combustion chamber when it's not supposed to---Again just an insurance policy---If it were my car ? I would absolutely keep the better springs---Insures catastrophic failures
from a valve that doesn't close--There may be more wear on your engine but not more than created by the SC !!!!--A valve job is much cheaper than a blown engine----
Old Nov 30, 2015 | 09:32 PM
Ajsegal's Avatar
Ajsegal
After speaking with Kohle at AH I decided im going to keep the springs. Forget what he said to be honest, but it was along the same lines as everything else said in here (boost=more pressure, cheap insurance, etc) he also said something about seeting them higher(I'm sure im using the wrong verbiage) for less pressure because of the stock cam? They will Only at 120psi or something like that. Anyways he made me feel alot more comfortable with those springs.
Old Nov 30, 2015 | 09:38 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
If you take a stock intake valve, call it 2" diameter, 1" radius = 3.14 inch^2. Spring pressure, say it's 120lbs closed (I've seen these quoted as being closer to 80lbs closed, which makes this example even worse)
Say you're at 12psi of boost
Total pressure on the back of the valve is 3.14 inch^2 x 12 lbs/in^2 = almost 38 lbs of force pushing the valves open. So, about a third of your spring pressure is gone (half if you use 80 instead of 120 lbs)
Does it really work out exactly like that? Hell if I know.. but that's the math I was shown when I asked why valve springs are a good idea with FI applications.
To Valve spring question
