c6 vararam dyno
Varraram claims that their CAI will actually PACK some air into the intake--This is an area of huge debate whether true ---My experience is that yes the varraram may pack some additional air in but only at high speeds--like over 100 MPH and only like 2-3%
Most often however the Varraram will require tuning---Not from adding so much air but from the re-location of the MAF sensor---Usually you will get a lean code--A lean code pops up when the % goes over 25% lean----That would be a huge increase if in fact true- But it's not--It is simply from a MAF re-location----In order to get the fuel trims corrected does require tuning with most any CAI but it's normally about a 10-13% airflow increase----
The P/T fueling will eventually learn out on it's own after about 50-75 miles of normal driving---But until then the added fuel from the leaness will also be added to your WOT fuel as well as a lean safety---So what you end up with is an engine lean at P/T and rich at WOT-----Tuning eliminates this learning curve----especially if erroneously the varraram shows a 25% leaness----( which will add 25% to your WOT fuel making it pig rich and lazy)
did i relocate the maf right?
Hence when the intake starts to pull in hot air from the engine bay being head soaked, timing is pulled and you lose HP instead.
So the HP numbers claimed for the CAI, is the difference from a standard OEM that may be pulling in much hotter air instead. Hence since during a dyno run, the hood is left open and a fan is blowing cool air into the engine bay, both a CAI and OEM intake will make the same power. It when the engine is closed, your sitting at a stop light too long with no new air into the engine bay to cool it back down, that you will see the HP saving instead from a CAI system.
As for some Cai's, then produce a lot disturbance through the MAF, instead of the smooth air flow that the OEM creates past it, so often tuning is required to correct for the less then smooth flow across the MAF itself.
Bluntly, all you need to do is prop the OEM shroud slightly open, and this will get enough cold air into the OEM filter to solve the heat problem. Better yet, since the oem system produces smooth air through the Maf, no retune is required.
To add, the IAT sensor is part of the MAF sensor.
So while a CAI will likely add HP (or more accurately, prevent loss due to heat soak), don't expect significant dyno increases. Factor in the innate efficiency of the stock LS3 intake and a CAI truly only helps at speed.
The factory air box system is hugely restrictive with a paper filter--Simply going to a cotton filter or the new synthetic fiber filters that have "0" restriction will in fact allow more intake airflow--equaling more HP--
PLUS the factory air box makes the air make a hard 90* angle turn with the flat filter
Aftermarket CAI's tend to have either a cone style filter or a multi sided open filter element----This eliminates the stock 90* angle turn ( a huge airflow path restriction)
Finally heat soak comes from erroneous readings from your IAT sensor----Even an aftermarket CAI will heat soak the IAT just as the stock airbox will----I have seen almost no difference in IAT temps even with the best of CAI's
The only way to eliminate the false IAT temps is with a full tune and not a handheld programmer--HP or EFILIVE has direct access to the entire IAT timing deduct table so you can custom tune out the false readings (maybe even Diablo) ask them
It is not uncommon for any car to have the IAT temps spike to 130* especially in traffic or city driving---Having an IAT temp of 130* will remove as much as 7* of timing from an LS engine--even if the outside temperature is only 60*---- So saying a CAI will reduce IAT temps in my opinion is NOT a valid reason to buy one---You must have it tuned to eliminate the false readings----The benefits of a CAI is unrestricted airflow
As far as your new MAF location I can't say because I don't know exactly where the stock location was----You can find out yourself with most any scanner that shows real time data---By disconnecting the battery so all your fuel trims will re-set---Then with a scanner LOOK at your "LTFT's" Normally a relocated MAF will show a huge POSITIVE fuel trim--like over 15%--A CAI will also show even more of a positive LTFT as more air is being allowed into the engine----In order to get a LEAN code which is common with the Varraram means that the total positive trims have gone beyond 25%--that is huge and must be corrected with tuning
bone stock, I went 12.463 @ 115.65
that weekend I installed the CAI and went to the track 7 days after the first pass.
CAI only, 12.232 @ 117.54
I didn't have any tuning issues or any problems with the MAF sensor. As a matter of fact, I didn't even tune it at all until I did some other things to it.
Filter types that have higher airflow must either have more surface area or less restriction. The only way to have less restriction in the same number of square inches, is to have bigger spaces between filtering media, which translates to less actual filtration. i.e. more air is also more dirt.
The shape of the airbox after the filter is far more important to increase the velocity about 4 fold than the filter media. Of course, any restriction that doesn't contribute to the velocity or control turbulence, will also reduce the total airflow.
MAP data logging at WOT will tell you if you you have problems or not with the air filter "system" not flowing enough air for the motor intake needs.
Also, data logging on the MAF sensor will tell you if the air flow through the system/sensor is clean or not as well.
I plan some mods (including HP) to make it more track ready. I just feel opening up as much air flow to the radiator as possible, will be better in the future, so I am planning accordingly.
