Modding list incomplete help me please
Old Dec 4, 2015 | 05:06 PM
Mitchem1992's Avatar
Mitchem1992
Default Modding list incomplete help me please
Ok I have a 2007 ls2 m6 car that I'm beginning to mod. The guy that was going to do my install and tune I'm losing confidence in when the guy tell me to ask someone else what parts I need. my goals are to be at 500rwhp n/a (just a goal not stuck on the number just want to be close) then a 100 shot of nitrous. BTW this is a budget car. My mods list is......
BTR LS3 HEADS
FAST 102 MANI LS3
BTR STAGE 4 CAM
TRUNION UPGRADE KIT BTR
MGW SHORT THROW SHIFTER
MANTIC TWIN CLUTCH
BTR 102 NITROUS KIT
That's what I got so far I know that I'm missing some small stuff. I don't know what length of pushrods I need or springs.
Old Dec 4, 2015 | 07:37 PM
donZ's Avatar
donZ
Better have a big budget, what about headers ?
just bolt on a super charger and be done....
Old Dec 4, 2015 | 07:45 PM
Suds's Avatar
Suds
Headers and high flow cats
Under drive pulley
CAI probably
Dyno tune
Old Dec 4, 2015 | 08:14 PM
Mitchem1992
sorry didn't put it in there I already have the lg lontube headers. So an under drive pulley can you explain why? I don't really want to go supercharger id like to stay n/a with nitrous.
Old Dec 4, 2015 | 08:19 PM
Suds's Avatar
Suds
Underdrive crank pulley is a common mod for reducing the parasitic loss on the front of the motor.
Old Dec 4, 2015 | 09:09 PM
highrolrcustoms's Avatar
highrolrcustoms
I dont think you will get 500..... it will be close but below are my mods and and you can compare
06 LS2 M6
Stocks heads
FAST 102 intake
NW 102 throttle body
RPM Custom grind cam
Kooks 1 7/8 headers
Kooks 3" catless x pipe into dumps
K&N CAI
160 thermostat
Dynoed at 445rwhp/416tq
Spraying 150 shot made 568rwhp/646tq
Old Dec 4, 2015 | 09:48 PM
Mitchem1992
I may not hit 500 that's just a goal not a set number I absolutely have to hit. you only get disappointed in your numbers if you're trying to reach something. I think with heads and the btr stage 4 I may get very close if not at 500 estimated and I only want to do a 100 shot without bottom end work.
Old Dec 4, 2015 | 10:04 PM
highrolrcustoms
Bottom end will hold the power just fine. ECS has many LS2 cars over 700rwhp on stock bottom end. RPM who built mine did a LS2 that is making 821 on stock bottom end. We are getting ready to turn ours loose with a supercharger and meth. Goal of 700+ without bottle
Old Dec 4, 2015 | 10:06 PM
highrolrcustoms
BTR LS3 HEADS
FAST 102 MANI LS3
BTR STAGE 4 CAM
MANTIC TWIN CLUTCH
BTR 102 NITROUS KIT
Also i could be wrong but that BTR cam probably comes with springs and pushrods. I know my RPM cam came as a kit. Included Brian Tooley pushrods and springs
http://www.briantooleyracing.com/btr...-pushrods.html
Old Dec 4, 2015 | 10:11 PM
highrolrcustoms
Here is the cam i am running so you can compare. Its pretty aggressive
Old Dec 6, 2015 | 09:00 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
06 LS2 M6
Stocks heads
FAST 102 intake
Kooks 1 7/8 headers
K&N CAI
160 thermostat
Good set of heads and port match the fast 102 and you will be over 500whp w/ ALOT more power under the curve
Old Dec 6, 2015 | 09:13 PM
highrolrcustoms
I agree. Was looking into a set of TEA trick flow 225s but at $2600 plus fuel system upgrades we decided we are just gona throw on a supercharger and meth
Old Dec 8, 2015 | 09:06 PM
C U IN REARVEIW
Won't need a fuel system for 500whp......boost a pump will do.
Supercharger and meth system will be $6,000+ if you install it....
Old Dec 10, 2015 | 05:32 AM
Gering's Avatar
Gering
Tolero Apto Victum
OP: Take a look at these two items http://store.katechengines.com/bille...sioner-p2.aspx & http://store.katechengines.com/dampers-c41.aspx Some CF members have had to replace the OEM unit due to excessive wobbles and product separation. If you plan on doing a cam install, then that would be a good time to install the ATI super damper, that way you could save on labor cost. If you are not planing on doing a cam install, then you could play the wait and see game with your current damper, which may last you the life of the car.
Good luck with your mods!
To Modding list incomplete help me please
