I have a bad wheel bearing in the rear drivers side. I am going to buy another hub to replace it.
I want to know how difficult / possible to replace the bearings in my old Hub. I have a pretty good maintenance shop at work. I've pressed in many bearings in my time. Is there a DIY or perhaps a Video out there that someone could direct me to?
Don't even bother trying. You can get whole hubs for $100 with the bearings already installed, so there's no reason to press anything. Just unbolt the old and bolt in the new assembly and you're done.
I bought some cheapo ones on Amazon over a year and 40K miles ago and they're still fine. Gmb brand I believe.
Yes I am going to get one off ebay but I was wanting to rebuild the one that I take off and was wondering if anyone has done this.
People talk a lot of junk about cheap ebay knock offs but I have two on my Z28 (made in china) for well over 100,000 miles. What people don't realize is that a lot of parts are made in china these days and some on the things that are purchased at local parts stores are the same parts you see on places like ebay.
So, I had this brain fart that I needed bigger axles. They came with a flange nut that is not a GM nut and it has worked fine. Not sure if it matters that they are aftermarket axles or not. If you look at the nut in the picture it has about twice as much thread contact area as the stock nut.
When I changed both my rears a year ago, I torqued the new GM nuts to spec and then used the old nut to double nut it in place. I also sprayed the nut and remaining axle threads with a little white paint for driver side and red for passenger side. I do the front hubs the same way. I spray a small amount on the back side of the wheels, so I can quickly ID which wheel goes where. It's especially helpful when swapping tires at the track with very little light available.
After spraying the axle nut and thread, I took a black felt marker and marked a line to do a visual verification the nut is still tight.
Good idea! I just paint a strip on the nut to axle connection to see if the nut as moved.
Hard to find the right torque. GM changed it and I have read anywhere between 150# and 160#. I used 154#. Always use a new nut and red Loctite. Let the Loctite cure for 24 hours before moving the car per the GM TSB.
