Using Mich 285/30/19 on C6
Hence the car has sensors for the speed of all four tires at the wheel hubs that is calibrated for the 1.04" tire size difference front to back, and when the front to back tire size ratio is wrong, the car is going to throw all kinds of codes since it not seeing the front and back tires covering the same amount of ground.
Here is a tire calculator that you can input your front and back tire numbers to check to make sure that the tire size front to back diameters are close to being correct.
http://www.discounttire.com/dtcs/infoTireMath.do
Hence if you are running 245/40/18's on the front, and 285/30/19's on the rear, the tire diameters of the two against each other are way off . You would need to change out the front tires to 245/35/18 instead.
As for the smaller side walls tires, mixed blessing really.
The smaller the side walls, the less side wall flex and the better they are going to cornering.
The cons to smaller side walls, less defection in the tire sidewall to absorb bumps and could lead to a bent rim on bumps faster also the less flex the side walls has, the worse for acceleration dig out from a dead stop as well.
As for road coursing the vet on the stock base width rims, the widest you can get away with is 255/35/19 on the fronts, 295/30/19 on the rears without problems or the tires ballooning on the rims (.094 difference).
Note, 255/40/18F and 295/35/19R works as well.
Hence general rule 40F/35B, 35F/30B, or 30F/25B, to end up with the 1.04" rear tire larger OD difference when you have 18"F/19"B, or 19"F/20"B combo's.
