Ported TB or CAI or Both?
Old Dec 21, 2015 | 09:02 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
Default Ported TB or CAI or Both?
Have a 08 LS3,only thing other than stock is a tune.
Looking for improvement in throttle response and maybe
adding some power. What would be advisable,a ported
throttle body or a CAI or both?
Old Dec 21, 2015 | 09:42 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
If you just want it more responsive, throw a Vitesse Throttle Controller on it and it will be as responsive as you want it to be
Ported TB's and CAI's are way over rated IMO and ported TB's in particular are prone to issues
Old Dec 21, 2015 | 09:50 PM
timd38's Avatar
timd38
I have ported FAST intake and NW102 TB, works fine.
Old Dec 21, 2015 | 10:12 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
But.. would the TB be making a significant enough difference to be worth the cost on a stock intake?
Old Dec 21, 2015 | 10:15 PM
timd38's Avatar
timd38
I have a confession to make. I only bought the NW102 TB because it looked good.....
Old Dec 21, 2015 | 10:16 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
They do look good
Old Dec 21, 2015 | 10:18 PM
Dano523's Avatar
Dano523
Ditto, if you have the TM dialed out in the tune already.
If TM is still hobbling the motor, then start there.
Old Dec 22, 2015 | 09:54 PM
Suds's Avatar
Suds
What tune is on your car, canned or off a Dyno?
Also more hp gains come from headers than intakes.
Old Dec 23, 2015 | 01:19 AM
HOXXOH's Avatar
HOXXOH
A CAI like a Vararam will be a much greater advantage than a ported TB. The PTB is almost nothing on an A6, but will improve throttle response on a M6. A better economy choice for a power increase is to pickup either a Z06 exhaust manifold, cats, and H or X pipe, or a set of used headers.
Old Dec 23, 2015 | 10:17 AM
JimmyS5600's Avatar
JimmyS5600
Suds it was dyno tuned
Old Jan 1, 2024 | 04:05 PM
2000frcblack's Avatar
2000frcblack
3rd Gear
100% in agreement. I have the Vitesse Throttle Controller on mine along with the Attack Blue air filter. Pulls hard and also increased sound level.
Old Jan 1, 2024 | 05:32 PM
BadAV's Avatar
BadAV
Hope you realize you are replying to an 8 year old thread. The OP is at least still on the forum.
Old Jan 1, 2024 | 11:45 PM
sirdano's Avatar
sirdano
This 100% I had a tune. Bought a used one off a member here. I keep mine on 6 but at 9 I have to watch for police
Old Jan 3, 2024 | 09:52 AM
Kenny94945's Avatar
Kenny94945
My vote: Add the controller.
Then I'd look at the CAI or filters or DIY air mods.
If those don't make you smile, then go with an intake manifold and TB and retune.
Plus don't forget the exhaust portion of the horsepower equation
Good luck.
Old Jan 3, 2024 | 10:12 AM
slowtealz28's Avatar
slowtealz28
Push down harder on the gas pedal for better throttle response. IF the car was tuned and still feels sluggish then somethings not right with the tune itself. Ported stock TB will likely just lead to issues with minimal, if any gains. Vararam will definitely help the car at higher speeds. I would never install a "throttle controller" in any car, theres no reason.
Old Jan 3, 2024 | 11:17 AM
BadAV's Avatar
BadAV
The comments about push the pedal harder/further always come from someone who has never used a throttle controller and run one through the various settings.
Old Jan 3, 2024 | 04:25 PM
slowtealz28
You could be right. But when you have some of the best LS performance shops in the country tell you they have no use, can interfere with other electronics, and could potentially be a safety issue I take their advice. My buddy had one on his cammed and supercharged LS3 camaro, wasnt good. All it's doing is tricking you into thinking the car has better throttle response.
To Ported TB or CAI or Both?
Old Jan 3, 2024 | 09:06 PM
BadAV's Avatar
BadAV
A few people have had issues with throttle controllers; the vast majority do not.
My Vitesse has been installed since shortly after they came out, with zero issues. Mine is set on SP4, which to me approximates a cable driven throttle. It absolutely takes away the drive by wire throttle lag, which is amplified by the throttle mapping on LS3 where 50% throttle application only yields about 25 or 30% actual throttle.
Old Jan 8, 2024 | 02:40 AM
Dano523's Avatar
Dano523
Who tuned the car, and do they have the talent to retune the throttle mapping as well?
Hence nothing physical needs to be changed, just The sedate way GM throttle mapped the tune to make is soccer mom safe to begin with.
As for the throttle controllers, they only change the percentage of how the pedal reads per percentage pushed only, not the response times of the the throttle body in reaction clocking, nor do they change the stall timing and reaction time of the TB that get worse on the none Z06/ZR1, the more nannies are turned off as well.
Old Feb 29, 2024 | 01:06 AM
bignikmusic's Avatar
bignikmusic
i ported my tb because i was bored and got a msd atomic intake manifold. now i get a tiny whistle at part throttle from air going over the blade. so keep the little swirl ramp that is there.
