Drilling in Front Subframe
Old Dec 26, 2015 | 06:06 PM
quimbysr's Avatar
quimbysr
Default Drilling in Front Subframe
Need a sanity check here. (2005 Base Coupe) While replacing a power steering hose, I broke off both of the small bolts that hold the low pressure hose "cooler" loops to the front subframe. I've tried drilling them out, but I can't get them out (tried drilling it several ways). I'm sure these are made out of some sort of steel to be fused into the aluminum, and it seems tough whatever it is.
I'm thinking it may be better to just drill 2 new holes in the aluminum (easier to go after) and bolting it there. I'd probably drill out some 6mm holes, then use a nut and bolt. My question is, am I going to mess up the subframe by drilling 2 more holes through it?
Thanks,
V/R
Bill
Old Dec 26, 2015 | 06:19 PM
timd38's Avatar
timd38
I would drill and tap them and install stainless bolts.
Drilling through should be OK too.
Old Dec 29, 2015 | 09:07 AM
cyclesailor955's Avatar
cyclesailor955
Default Anti Seize
Be sure to coat the bolt threads with Anti Seize.
To Drilling in Front Subframe
