First time posting, so not sure if I am doing this correctly?
Problem: under hard acceleration (80 percent of full throttle) car is starting to fishtail and I have to back off throttle to regain straight line direction.
-2013 Grand Sport
-6 speed Auto trans
-tires at 30 psi cold pressure
-8000 miles on Factory Goodyear Eagle F1 Supercar EMT- worn to 4/32nds
-47 Degrees ambient temperature, dry road conditions
Is this due to:
Summer tires starting to harden in colder temps?
At what point should active handling or traction control be helping my problem? And what will I see (on the dash) or experience once these do kick in?
Dkoch:
In answer to your question: sheety tires in cold weather do not stick to the road well. Sudden input of full power in cold weather will cause them to break loose. Ease into addition of power and be mindful that at high rpm in the lower gears under full power that the tires can break loose also..been there done that even under warm temps. When they break traction, it is sudden and without noise. Respect the power you have and don't be shutting off the traction control till you know what the car is going to do under all circumstances.
That is the other question: at what point would that active handling kick in?? I was getting out of my comfort zone with the amount of oversteer, yet did not seem to notice the cars system correcting me....wish I could test it on a safe course to see what the engagement of active handling feels like.
I've noticed on our cars that traction control is pretty conservative. It feels like sport mode on most other cars I've driven. I'm with you though, it needs to be more sensitive. It would also help with keeping the tread on the tires lol
Ok! That is what I was hoping to get some confirmation on! I thought I was a bit of a whimp backing off the throttle when I did! I'm sure it would have kicked in by the time I was about to hit the center divider...right???
And you would think traction control would stop those tires from spinning much earlier! I need a track to get to know this thing better.
You are not a wimp if you back off. Too many heroes have totaled their cars and killed themselves and their passengers by not being a wimp. When the tires let loose, it is sudden and without noise. In the cold, you will get yourself in trouble much quicker and at lower limits than in the summer time and it will take a lot longer for the tires to rehook up when you do back off. Tread lightly when driving these cars in cold temps.
Yeah, the babysitter on the vette is obviously busy texting her boyfriend most of the time. I've gone full Dukes of Hazzard with it on in the wet. Yeeehawww.
They had two choices either have the traction control kick in early.Or have it kick in later.
I for one am glad they made it later.But it does take some getting used too.
Uncomfortable?? lift or don't push it as hard next time.No point in wrecking just because you arnt used to it yet.
When active handling kicks in, you'll know it. Especially if you're getting sideways.
Find a big open parking lot and learn how to handle it. I'd suggest either a helmet or open the window, in case the correction is on the violent side.
Cannot say how grateful I am for all of this great technical and practical knowledge you have. I was pretty scared, as I was going PERFECTLY straight when this happened. Hope to get to a safe place and feel this kick in.
You are right: ZERO noise was heard when it happened. I didn't think about it taking MORE time to hook back up, that's even more reason to not get into that situation on the road ever again.
