aFe Pfadt headers
Old Dec 30, 2015 | 05:23 PM
jstewart's Avatar
jstewart
Default aFe Pfadt headers
I have not really done much with my 2008 C6 since I initially modified it in 2009 and am thinking about taking it another step. In 2009 I installed a Kooks 1 3/4 header system with cats, Milled the heads .022, did a high performance Serti valve job, used .010 thinner head gaskets, had the stock intake & TB ported, installed a spinmonster spec cam & valve train, installed a 10% UD balancer/pulley assembly, retained the stock dual mode mufflers.
I noticed recently that aFe has started offering the Pfadt headers again. I want to know if anyone did any back to back testing with this Pfadt tri-y system to compare the results to the other major Mfgs systems. If aFe is producing the same quality product as the original Pfadt system the build quality should be top notch. In addition to considering this product I am considering replacing the heads and in take manifold. I know it would be simpler to bolt a supercharger on but I like NA cars and am looking for suggestions.
Old Dec 31, 2015 | 01:49 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
I wouldn't expect to gain much over your existing headers if anything.
Maybe you could get some trick flow heads or small bore ls7 heads if you're really dying to spend money on them.
Another option to keep yourself N/A and happy is to build yourself a stroker
Old Dec 31, 2015 | 06:05 PM
AIR_RAM's Avatar
AIR_RAM
If you already have a set of headers installed and everything is in good working order, I agree that it would not be worth the time or effort to swap them...
With that said, I installed the PFADT headers on my 2011 GS and they fit like a glove. They are truly a work of art both out and when installed. So in my opinion they are worth every penny and would be the better choice IF you where going from stock to Headers.
One feature I like about the TRI-Y is the fact that they are NOT as bulky at the bottom where the 4into1 headers merge. This means more clearance from the ground with the Tri-Ys over the 4 into 1 collectors. Less chance of a crushed or dented pipe from a bottom out... Again, this is mostly my opinion and I believe although the PFADT headers would give you an advantage the power gains would be minimal and not worth swapping out an existing set of headers.
Spend the money on a ATI Superdamper instead!
SPEED SAFE, NICK
Old Dec 31, 2015 | 07:49 PM
Suns_PSD's Avatar
Suns_PSD
What is your hp level currently?
Your upgrade options are sorry of limited as far as bang for the buck. The Vararam manifold, flex fuel conversion, 418 ci engine, Mamo TF heads, 1 7/8" headers, gears, etc...
Old Dec 31, 2015 | 09:27 PM
jstewart's Avatar
jstewart
I didn't give you all the mods. The car has a Vararam intake & a ATI 10% UD damper. The cam is spins 230/234 grind with supporting valve train (springs, Ti collars, pushrods, rocker arm upgrade). HP level depends on whose dyno, from 490 to 501 corrected. The comp. ratio is 11.4/1.
Not looking to set any records as this is strictly a street car. I would like to get to a solid 530 to 540 corrected, NA, RWHP without screwing up the decent street manners this car has. I don't drive the car a lot because of extensive travel (12,000 miles since it was modified in 2009). I suspect a set of Mamo ported TF heads and a Mamo ported Fast intake would get me there or close. I just don't know if the existing 1-3/4 Kooks headers with cats and the stock C6 dual mode mufflers will support another 40 HP.
Old Dec 31, 2015 | 10:03 PM
Suns_PSD's Avatar
Suns_PSD
The 1.75" headers are a problem for the power levels you are shooting for. The fast intake is a complete waste of money on the ls3. Vararam I'm talking about is a manifold ( similar to a fast). It's being touted as giving 25+ hp. if I had your car I would probably go to the 4 inch crank for a 418 cubic inch engine, CNC port the stock heads, and check out the Vararam manifold. All of that should give you about 50-60 horsepower but more importantly the torque and midrange will go up through the roof because of the big bore. And you should be able to do all of that for about seven grand. I have similar mods to you, and unfortunately the cost of each horsepower from here on out gets really expensive.
Old Dec 31, 2015 | 10:05 PM
Suns_PSD's Avatar
Suns_PSD
My plan is I am removing my ls7 manifolds and I am replacing them with one and seven eighths Kooks, I'm adding the Vararam manifold, I'm CNC porting the OEM heads, and we're going to do a flex fuel conversion. It should take me from my current 450 horse to somewhere around 500-510 rwhp.
Old Dec 31, 2015 | 10:07 PM
Suns_PSD's Avatar
Suns_PSD
As far as your original question about swapping headers to Pfadtd in an attempt to gain power, I believe that would be a poor use of money, you would be better off moving to a 1 7/8 Kooks headers. At the power levels you are talking about it should be good for a solid 15 extra horsepower. As far as your stock NPP even with the 2.5 inch inlet that should not be a hindrance when it's in the open position is what I have been told. Some even say the 2.5" makes more power than the 3" systems.
Old Jan 1, 2016 | 10:56 AM
jstewart's Avatar
jstewart
Who are you going to use for CNC porting on C6 heads? I could not find anyone back in 2010 who could verify that the Fast manifold for the LS3 made any meaningful difference over a properly ported LS3 stock intake. I have not been around the forum for several years so I didn't know if anything had changed concerning the LS3 Fast.
Another problem is traction even at my current power level. I started out using widened 11 X 18 stock rear wheels with Nitto 555R tires which worked pretty well. When these were no longer available I bought a set of LG world sport wheels (11 X 19 rear & 10 X 18 front) and am now using Nitto Invos. Good for wear and decent traction but nowhere near the grip the Nitto 555R's had. Any suggestion on a 19" replacement that has the grip of the old 555R?
Old Jan 1, 2016 | 11:41 AM
jstewart's Avatar
jstewart
Just did a search for the Vararam manifold along with comments on this forum. Reminds me of all the excitement over the LG ram air intake which hung out there for several years but never became available commercially as far as I know. Looks like the same story so far with the Vararam intake. Hope Vararam quality control is better on the intake manifold than the ram air intake I bought. I tried 3 cold air intakes and the Vararam had the poorest fit of the three. I talked to Vararam about the less than expected quality at the time and they didn't think I had a problem.
Edit: I stand corrected as the LG super ram is now available. Like I said I have been off the forum for quite a while.
The 416 stroker is looking more & more attractive with some supporting modifications. Need to do more research.
Old Jan 1, 2016 | 12:59 PM
Suns_PSD's Avatar
Suns_PSD
I'm using TX Speed for my heads as they are local and good. Lethal in Schertz, TX will do the R&R and tuning. If you don't mind the cash the Mamo ported TF are better, but they aren't 5x better which is how much more they cost once you have to buy new rocker arms too (i have the some issue, already have Yella Terras). I think that price difference pays for half a stroker kit which will give you a lot more power overall. Texas Speed can build the stroker engine with the heads all done for about $5k. They aren't the only ones either. There are some companies (ECS?) that can install liners and get you more displacement. 454ci and what not!
I have a mini tub with 345 tires on 12.5" wheels. Use the Toyo R888s. They stick really well and will last plenty long for your mileage.
Old Jan 6, 2016 | 10:39 PM
JRLedFoot's Avatar
JRLedFoot
check out this video, it explains the differences in performance between an LT 4 into 1 header and tri-y...
Old Jan 7, 2016 | 12:45 AM
sevinn's Avatar
sevinn
Another option would be to switch to a low lash solid roller setup. People are making serious power with them.
Old Jan 7, 2016 | 11:59 AM
Unreal's Avatar
Unreal
Every single tri-y to solid 4-1 comparison I've seen gained plenty of power everywhere. Tri-ys are tuned fora specific combo/engine camshaft. On a bone stock car they can make more low end, or if you have a set built specifically for you motor/combo, otherwise I've seen ARH/Kooks gain 7-8rwhp and power everywhere over pfadts time and time again.
Old Jan 7, 2016 | 07:10 PM
old motorhead's Avatar
old motorhead
You've reached the point where a little more power is going to cost a lot more....unless you add forced induction. Do you think you can really feel 30 or 40 more hp? It will show up on the dyno and barely noticeable at the strip. With 10psi and meth, you can skip the 5 and 600 hp levels, and go straight to 700+. That, you can notice.
Old Apr 21, 2016 | 06:52 PM
jstewart's Avatar
jstewart
Thanks for all the feedback guys. Since I am not interested in either forced induction or nitrous I am going to turn the car over to LWA in Atlanta. I think I can get 550 RWHP that is street friendly by using a 402 stroker and massaging the LS3 heads in combination with the correct cam. They have built some pretty impressive NA street motors out of their Atlanta shop (leavinu is currently at 600 NA HP which he street drives everywhere). His car has shown that Rob and his crew at LWA can get it done. TX Speed & Lethal are further than I want to take my car but very capable shops. LWA in Atlanta is far closer to me and after some research I feel confident they can get the job done right.
To aFe Pfadt headers
