Does your corvette sway?
Old Dec 31, 2015 | 09:02 PM
Biggraz's Avatar
Biggraz
Default Does your corvette sway?
Ive had my corvette for about 2 months, bought it preowned with 7000 miles. The car on the highway pulls right and left constantly, sometimes it's actually pretty bad were I have to correct it pretty good. My father has a c5 corvette and it does the same thing so I'm trying to figure out if this is normal or what? Does anyone have this problem?
Old Dec 31, 2015 | 09:41 PM
ROBMARZ's Avatar
ROBMARZ
Zero "sway" on mine
I'd start by checking the alignment and tire wear.
It is definitely not normal.
Old Dec 31, 2015 | 09:48 PM
Biggraz's Avatar
Biggraz
Originally Posted by ROBMARZ
Zero "sway" on mine
I just had the alignment done, I think it's the factory run flats they ****ing suck.
Old Dec 31, 2015 | 09:54 PM
russ472's Avatar
russ472
its probably tramlining. mostly caused by your tires.
Old Dec 31, 2015 | 09:55 PM
ROBMARZ's Avatar
ROBMARZ
If the alignment is good, you are probably right about the GY's. I went to Michelin PSS and they are great.
Old Dec 31, 2015 | 10:08 PM
Dcasole's Avatar
Dcasole
Same here .... was not bad but I felt it . Since changing to the Michelin PSS it handles and drives great
Dave
Old Dec 31, 2015 | 11:19 PM
bobeast's Avatar
bobeast
These things should drive like the proverbial rocket sled on rails. Definitely not normal. Another vote for the Michelin PSS.
Old Jan 1, 2016 | 01:28 AM
owc6's Avatar
owc6
This is especially noticeable with wider tires (GS,Z06,ZR1), or summer( stickier tires).
Pulling in both directions is usually not an alignment issue, but at 7,000 miles, the car has had enough time to settle, and getting an alignment done is probably a smart thing to do at this point.
Old Jan 1, 2016 | 11:47 AM
miamiguy305's Avatar
miamiguy305
i had the issue with the factory run flats, i went away from the run flats and no more issues your right the factory tires suck !!
Old Jan 1, 2016 | 04:30 PM
jcarter29072's Avatar
jcarter29072
Default Pulling
I am having the same issue, but after much research, I have concluded the Michelin's are the best riding tire, but that is no guarantee it will solve it 100%. Do a You Tube search on Tramlining. See if it doesn't fit your complaint to a tee. Also, be sure to run the recommended tire PSI. These cars are finicky about tire PSI.
Hope this helps!
Old Jan 1, 2016 | 07:48 PM
C6z06man's Avatar
C6z06man
Mine has gotten much better with going to Michelin PSS. However the wide tires do struggle to ride straight and smooth when on roads with "grooves." I travel a road with a lot of truck traffic and the one lane has sort of "worn grooves" from the heavy trucks. I can feel my car sort of slide in and out of the grooves. Feels like ice the first few times. Your issue could be any or all of the above.
I also know I need an alignment but won't be doing that until I get it out in the spring with new front tires.
Old Jan 1, 2016 | 09:59 PM
Purple92's Avatar
Purple92
I completely agree with C6Z06man - wide tires WILL be more susceptible to following ruts in heavily traveled / worn roads. That is just part of the game with Higher Performance cars. If this is the issue - the car will tend to pull to both the right and the left, and the problem will all but go away if you drive over a freshly paved section of roadway that's actually flat ... Is that what you're experiencing ???
Now - you say you just had your alignment done... OK - what exactly does that mean - if it means that you took your car to the dealership and they verified that your car's alignment is within specifications, that's nice, but in all honesty - it's relatively meaningless. The factory "specs" have tolerances that are QUITE LIBERAL (the front camber spec on a Z06 is literally +/- half a degree)... Before you write off what you're experiencing as a problem with the alignment - take your car to a shop that has good alignment equipment, and good techs, and have them align the car to something like the PDAF street alignment specs. These specs are pretty much a subset of the factory specs - but with MUCH less tolerance permitted).
IF you still have a car that pulls after a proper alignment, and while on a freshly paved section of road - you need to dig further - you may have a worn part in your suspension or steering systems....
Old Jan 2, 2016 | 04:45 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
mine sways a little bit but only when changing Highways at 80 mph.
I agree with the rest get some Good tires. I like my Michelin SS.
Old Jan 2, 2016 | 04:52 PM
Boomer111's Avatar
Boomer111
Sounds like you need some toe.
To Does your corvette sway?
