How good is the LS3?
I'm talking about other wear and tear parts. It's 10 years old now, with over 80k miles.
What about brakes? Tranny fluid? Diff? How do you know those were properly changed if changed at all?
What about the clutch? 500hp at 80k miles on a stock clutch is pushing it. Like i said the car was probably beaten. And other hoses, wiring, the radiator, the electronics early model C6's gotten. The list goes on and on.
I know it's hard to turn down the Z. It's a beast. It really is. But sometimes in life you have to look at priorities, your budget, and what's the best purchase for you. Actually no not sometimes, all the time lol.
IMHO, if i was in your shoes, i'd get the LS3. Or save a bit more and get the GS. Because like i said, best of both worlds.
I know i sound biased because i bought a GS. Best decision i ever made. I was in your shoes. Hence my username. BUt i did my research and actually spent a bit MORE to get the GS. 6spd coupe in red. My favorite color.
Best of all, i bought it with 6k miles. 6000. I just hit 10k today actually lol
edit: not sure why the picture came out like that.
There's no buyer remorse here for not getting the Z. I actually got my GS w/6 miles on the clock. I wish I snapped a photo of it when I first got it. I know ...I'm pretty sure it wasn't beaten on w/in the first 6 miles.
So now we are at 40K too rich for my blood.
The extra plastic makes her flow nice! Hinson Headers w/ catless x pipe, Halltech intake, Vitesse throttle contoller, and Diablo Trinity. New Michelin Super sports. Cant imagine her any faster...Don't want to, scary right now! Good luck!
Update here on my 2013 GS w/the Dry Sump LS3. (I posted the shot with 318 miles on the odometer) It's running great & I just went over 30k miles on it. I can't stop driving this thing. It's been across the country & back. I also went up in Canada to Niagara Falls. What a car!
Thanks!
Engine, brakes, suspension, and even the lighter/stiffer aluminum frame of the Z06 (compared to the GS's base model steel frame), all make a difference between the two models.
The LS-3 is a good motor, but could have been better instead. Hence it's a upgrade from the LS2 block to be stronger, with a touch more displacement, but GM dropped the ball by dropping the compression on it to make is more lower Octane friendly to run cheap gas through the motor instead.
So what the GS is, is just a base car with wide fenders, and a z51 option instead. So if want a daily cruiser, then the GS fits the bill since you can even remove the roof from it, but come round course event, the Z06 is going to stop the GS into the ground.
Yes, you can throw mods at a GS to get it close to the a Z06 in some ways, but come resale time, all the mods done to the GS will not pay back in the end, when compared to selling a stock Z06 instead.
Hell, used car, and having to drop $2k into the LS-7 dropped valve problem to make sure it;s solved, that is a drop in the bucke, since new super sport tires to replace the aged tires on the car will run you close to $2k anyways in either the GS or Z06.
Bluntly, before you buy a vet, make sure you are buying the model you want to begin will. Hence compromising from the start, will end up being more expensive in the long run isntead.
Also, you are buying a Vet, not a Honda civic that will be trouble free for 100K, so up kept on the sports car will be a lot more expensive as well (so much, that if you maxed your available money on the payments to buy it, your not going to have the needed money to maintain it instead).
Truth is, more vets are sold to just get ride of them, then are sold to upgrade into a new model instead. Because of this, be very, very leery on buying a used vet with higher mileage, since you may just be buying someone Else's problem that did not have the money too fix the problem in the first place instead.
The LS7's is a beast. LS3's are great motors, but no matter what body kit you put around the LS3 it still isn't a ZO6. If funds are not too much of an issue, go with a nice Z. You'll never be satisfied with the LS3 if you're already questioning it against the LS7. If your budget is only for an LS3, you'll be more than happy. My budget a few years ago was for an LS2, I am more than happy with it, but the time now has come where I need more power so headers, FAST and tune are in it's future. All C6's kick a$$, but the Z IMO is where it's at.
It comes down to wanting the real deal...or a base vette with a bodykit.
Buy the car that meets your needs, not what makes the people on this forum happy. If you want a wide body car with a removable top, then the GS is the way to go. If you want a no-compromise version, get a Z06 or ZR1. If you want the economical version and don't care about the wide body, get a base. If you want an economical version that has enhanced handling, get a Z51. And so on...
Each of the models and option packages have upsides and downsides and the possibilities are endless, but only *you* can determine what is the right car for you.
