Time for new tires
Old Jan 2, 2016 | 02:47 PM
FirstTimer Pops's Avatar
FirstTimer Pops
Default Time for new tires
Time to replace original tires. Only 15K miles, about 3 years. Is this what you guys have seen from your tires?
Recommendations from those that have changed tires from the original Goodyear Eagle F1 Supercar tires? I will not track the car, just an everyday driver in San Antonio Texas, where it gets to over 100F only a few days in the summer, and rarely goes below freezing in the winter.
Thanks for responding.
Pops
Old Jan 2, 2016 | 02:52 PM
Cherokee Nation's Avatar
Cherokee Nation
Myself and many others have the Firestone wide ovals RF's.Very good summer tire and a lot cheaper then others. I'm on my 2nd set.
Old Jan 2, 2016 | 04:16 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
I got well over 28,000 miles off my 1st set of Michelin run flats, don't remember which ones but they were Verrrrrry Expensive. I now have Michelin SS non- run craps and like these Better, 21,000 miles and still looking good.
KEY Point-------- Get the Proper Alignment.
Old Jan 2, 2016 | 04:49 PM
Steve Haefner's Avatar
Steve Haefner
2018 C6 of Year Finalist
Lot's of guys running Michelin Pilot Super Sports, The less expensive good tire is the Cooper RS-3. my .02, and yes as ls1121 said get alignment after.
Old Jan 2, 2016 | 04:52 PM
timd38's Avatar
timd38
Michelin Super Sports for me. They are such a good tire I put them on one of my other cars as well!
Old Jan 2, 2016 | 05:07 PM
Dcasole's Avatar
Dcasole
Dave
Old Jan 2, 2016 | 06:24 PM
dmoneychris's Avatar
dmoneychris
I had GY supercar tires on my Grand Sport from the factory...They were pretty much worthless in all aspects...The Michelin PSS that I upgraded to are the best tires I've ever driven on. You won't be disappointed if you go with the PSS non RF.
http://www.tirerack.com/tires/tires....oModClar=Coupe
Old Jan 2, 2016 | 07:01 PM
FirstTimer Pops
What do you do to get around not having run-flat capability with no spare?
Old Jan 2, 2016 | 07:08 PM
dmoneychris
....I don't worry about what 'could happen'.... I just drive the car & enjoy it. I try not to worry about the possibility of a flat.
Old Jan 3, 2016 | 09:04 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Originally Posted by firsttimer pops
what do you do to get around not having run-flat capability with no spare?
aaa
Old Jan 3, 2016 | 10:24 AM
pyrodav's Avatar
pyrodav
MPSS, I keep a plug kit and 12v air compressor in the glove box.
Old Jan 4, 2016 | 12:02 AM
Bat66's Avatar
Bat66
When i purchase my 07 it had a new set of firestone run flat I replace the stock rim with the z06 spyders and an alignment, im down to 3/32 with over 33000 miles, will be ordering a new set from tirerack next week.
Old Jan 4, 2016 | 07:50 AM
Tennis_pr0's Avatar
Tennis_pr0
I think Nitto Invos perform better than MPSS and are almost much cheaper. Continental DW's are also good at around the same price.
Old Jan 4, 2016 | 07:36 PM
jrose7004's Avatar
jrose7004
I went to Firestone Firehawk's and have been very happy with them.
Old Jan 4, 2016 | 10:31 PM
FirstTimer Pops
Default I don't see Firestone Firehawk Wide Ovals that fit
I looked on the Firestone website to check out pricing. When I put in 2013 Grand Sport, it does not return a tire that fits.
Old Jan 4, 2016 | 10:34 PM
FirstTimer Pops
Default Proper alignment?
Is Proper Alignment equal to stock alignment?
Old Jan 5, 2016 | 08:01 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
These are the PFADT Street alignment settings that have been discussed here if you search that seem to be the consensus settings for street cars.
Performance Street
Front min max
Camber (deg) -0.7 -0.9
Caster (deg) 7.5 8.5
Total Toe -1/16" (0.17°) 0 (0°)
Rear
Camber (deg) -0.4 -0.6
Notes
These settings will provide good performance and good tire wear
As for tires for a GS, there are several choices. Check Tire Rack, Discount Tire and Tread Depot website and you should sees all of the available fitments. I went with the Coopers (special ordered from a local Discount Tire at about $900 total with tax and road hazard for all four) and they are OK for the money but do give up a little in straight line traction under hard acceleration. Otherwise they're OK for the street.
I'll probably go with Nitto, Continental or Michelin next time.
There are many threads here regarding tires if you search.
To Time for new tires
Old Jan 5, 2016 | 02:50 PM
Cherokee Nation
I have the Base,I don't think they make GS or Z06 sizes yet.
Old Jan 5, 2016 | 03:19 PM
Steve Haefner
You would have to shop by tire size.. for the GS
P325/30ZR19 rear
P275/35ZR18 front
http://www.firestonecompleteautocare...m=19&zip=63366
Old Jan 5, 2016 | 04:26 PM
extrapilot's Avatar
extrapilot
Me to, or is it three.
Check out tire racks personal reviews; this is what sold me on them. Anything better would be Michelin , for little more coin.
