Fly cutting stock piston
Old Jan 3, 2016 | 08:58 PM
Last 1's Avatar
Last 1
Default Fly cutting stock piston
how much can you cut them an still be safe for a N/A motor
Old Jan 4, 2016 | 08:12 PM
Last 1's Avatar
Last 1
nobody
Old Jan 4, 2016 | 08:53 PM
Steve Haefner's Avatar
Steve Haefner
2018 C6 of Year Finalist
Nobody has responded because it's generally a bad idea. I'd recommend you consider a different camshaft that will not require the stock pistons to be modified.
Old Jan 4, 2016 | 10:52 PM
xBoostx's Avatar
xBoostx
Default Repost...
The piston pin boss (reinforced area) is rite behind the valve possible area of contact so the piston is plenty thick in that area I removed .125 off mines no problem running 14.1 to one on e 85.
The piston list thick are is .250 but not withing the area.
To Fly cutting stock piston
