Cam and valve seal help.....
Old Jan 11, 2016 | 10:35 PM
REEPERC6's Avatar
REEPERC6
Default Cam and valve seal help.....
How's it going, guys!!?? First, I'm new to the website and want to thank everybody in advance. I bought a 2008 C6 and love it. It has a cam, Kooks long tube headers and a Kooks catless X-pipe. At idle I get blue smoke. From what I understand, that is caused by the valve seals. I want to get the valve seals done, but I'm not sure what cam is in the car. My questions are, do I need to know which cam is in my car to get the correct valve seals? And I'm I being told correct that I will get the blue smoke at idle with bad valve seals? The car has 55k miles and i don't get any smoke under hard acceleration and the car is very strong. Again, thanks for any info and advice.
Old Jan 12, 2016 | 09:51 PM
rpmextra's Avatar
rpmextra
Yes that could very well be the seals.
the cam wont change the seals but your current valves springs might. if you have a single spring then you would be best with a oem seal. If you have a double spring set up the base of a stock seal will interfere with the inner spring.
