2008 Z51 coupe. I had forgotten how much fun it was to hook up the mid-pipe to the cat pipe and mufflers. Does anyone have a procedure that makes this easier for one person to do? Sequence of connecting parts, etc.?
If you're swapping manifolds too then I try to leave everything snug'ish but not tight until everything is together. You can get a little bit of adjustment on the manifolds/cats which can sometimes make things easier
Hardest part for me is always getting the axle back to connect to the H pipe. It's always tough to get going but it just takes time to get the alignment right then brute force twisting them back and forth to get them to go together. Sometimes they go right together, sometimes not so much.
That is what I remember when I put the z06 exhaust system on. It looked impossible for one person to accomplish, then suddenly the mufflers slipped into the mid-pipe and it was done. I guess I just need to struggle with the stock system for a bit.
GM made changes involving the end of the mid pipe and start of the axel over. Not all C6 yrs are interchangeable.
RU sure of the capatability?
Yes. It is the stock system the car came with from the factory. I removed it to put a z06 exhaust system on. Now I have to return to stock to do the emissions recall everyone speaks so fondly of.
Best advice I can give you to get the muffler pipe tips straight without someone helping, before you clamp down muffler to X pipes brackets, use a piece of wood on a floor jack to try to hold the muffler pipes level.
Even with this, your still going to have to go back and re-adjust, once the pipes do a few heat cycles. So having said that, put scribe lines between the two, so when you have to go back and readust the muffler,you have a start point on the two pipes to clock again each other. for the needed rotation on the muffler pipe at the K pipe.
The struggle is getting the mid pipe connected to the mufflers and the cat pipes. Doing this yourself is a real challenge.
You got that right. Getting the z06 passenger side muffler in and out is a challenge and requires lowering the transaxle about 1/2", but the real challenge is getting the pieces to fit back together. If the fit was not so tight between the mufflers and the mid pipe, things would be a lot easier. I wonder if slightly expanding the mid pipe so the muffler pipe would fit into it a bit easier might be the trick.
Buy a lift. Keep everything loose until all parts are together. The lift makes the job easy for one person. I've had my Z06 mufflers off a few times and never lowered the transaxle.
Regarding the original question....exhaust pipe expander. Any good shop will have one if you can get your mufflers to them. Couple taps with the impact gun and the pipe will be a 16th bigger and more importantly round. You just need to expand the first half inch of the pipe where it's already split. It'll then slide right onto the intermediate pipe and the factory clamp will tighten them up just fine That's the whole reason the pipes are slotted on the end.
Got a lift. Can't see any way that passenger side can be installed or removed without lowering the transaxle. I remember when I installed the system I found the same thing. Tried everything I could to get the axle over pipe in but finally had to lower the transaxle. Do you have a m6 or a6?
I've done it with rear cradle, etc. installed. It's a really tight fit on the passenger side because of all the evap junk on that side. It's easier with the rear lowered a little bit for sure
I have done Z06 mufflers exactly how I wrote, there is no need to lower the transaxle.
Do you have a diff cooler installed?
If so, remove the heat shield above the exhaust.
Then support the driver's side fuel tank and remove the screws tha support the fuel tank pan, and remove it. This will give you a little more room to get the end of the pipe up and over.
DJ
No diff cooler, but removing those parts would give your the same room dropping the transaxle a bit. Not sure which one is easier. I know you need to be careful lowering the transaxle to avoid damaging the torque tube.
M6. As 96GS said drop the sway bar out of the way. His pic is what I did. The passenger side is definitely tight but rotating the muffler back and forth I was able to get it in there.
