Dumb clock issue
Old Jan 19, 2016 | 08:35 PM
Troy's Avatar
Troy
Default Dumb clock issue
I live in the Mountain Time Zone. My clock is stuck in the Eastern Time Zone. It used to work correctly by about a year ago it decided to screw with me.
I can reset the clock to MST and hit the GPS Time Button. This keeps it in the MST while I am driving. But as soon as I shut the car down and start it up again its always switched back to EST. Very frustrating!
The battery is fully charged.
The GPS must work because the NAV system works and knows where I am.
Any idea on how to fix this?
Old Jan 19, 2016 | 09:31 PM
EVRose's Avatar
EVRose
After you set the clock and the region correctly push the memory button on the door that matches which fob you use till it beeps to save the settings.
Old Jan 19, 2016 | 10:10 PM
jrose7004's Avatar
jrose7004
My 10 Cadillac did that and they ended up replacing the whole nav unit, lucky for me it was under warranty.
Old Jan 19, 2016 | 10:22 PM
HK770's Avatar
HK770
Eastern Disc in GPS, confusing Clock ??? Just a thought.....LOL
Old Jan 20, 2016 | 12:03 AM
Troy's Avatar
Troy
Its worth a try. I'll let you know.
Old Jan 20, 2016 | 12:04 AM
Troy's Avatar
Troy
Sounds odd but I'll check. I'll try anything at this point.
Old Jan 21, 2016 | 05:23 PM
Troy's Avatar
Troy
It was a good idea so it tried it. Didn't work, sorry to say.
Old Jan 22, 2016 | 12:48 PM
cclive's Avatar
cclive
I'll be interested to see what effect the new NAV disc has on the system.
Old Jan 22, 2016 | 01:25 PM
Troy's Avatar
Troy
Sorry to say, no change with the clock problem after installing and exercising the new Nav disc.
Only change is the Nav has decided an east coast region is the default region. Previously the west coast was the default region.
Old Jan 22, 2016 | 02:18 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I haven't read that you have done this yet.
COrvette Owners manual Go to page 58
Old Jan 22, 2016 | 02:59 PM
Cherokee Nation's Avatar
Cherokee Nation
Like I said in the other post the nav should have nothing to to with the clock. I removed the disk and my clock works fine.
To Dumb clock issue
