Differential
Old Jan 26, 2016 | 01:02 AM
Sleeplater's Avatar
Sleeplater
Default Differential
My dif went bad I used to Drag race years ago, I got 583 RWHP , I believe its a 2.56 ratio
2006 C6 A6
Please give me ideas miss my ride
305-790-0278
Old Jan 26, 2016 | 07:20 AM
timd38's Avatar
timd38
Several great builders on the forum that can help you with a stronger diff. I did mine myself and that was a mistake. RPM, RKT, ECS, etc.
Old Jan 26, 2016 | 07:37 AM
xBoostx's Avatar
xBoostx
2006 C6 A6
305-790-0278
I just changed my diff after a heads and cam and went for the ZR1 3.42 the one i removed have 23k miles and is out of a 2011 A6 grand sport and has the factory 2.73 gears upgrade in it, if you can use that let me know.
You may have to change your input shaft on the trany sense these I believe comes with the heavy duty Z input shaft, i can work you out a good deal I'm rite here in Miami I can install it for you as well or help you out.
Old Jan 26, 2016 | 08:30 AM
Jeremy@RPMTransmissions's Avatar
0Jeremy@RPMTransmissions
Former Vendor
Hi,
We have many different options for a differential in your C6. Our most popular is the 3.15 and 3.42 Stage 3 build. We would be happy to build you one and get you back on the road.
Give me a call at 1-800-406-1109 and we can discuss what would work best for you.
Thank you,
Jeremy
timd38's Avatar
timd38
I think the auto trans and Z have the same spline shaft.
Old Jan 26, 2016 | 08:36 AM
Sleeplater's Avatar
Sleeplater
I am interested please call me 305-790-0278, anymore inputs please chime in!
Old Jan 26, 2016 | 09:29 AM
CI GS's Avatar
CI GS
Yes, that is correct. I installed a Z06 diff in my 2013 GS. Straight bolt-in deal, except that you need some plugs for the oil cooler lines on the Z diff. I bought the kit for that from Zip along with the new diff.
One thing that has been noted however, is that, because of the larger ring gear diameter in the Z06 diff, the splines on the output shaft of the A6 do not engage fully in the pinion, to the order of about ~3/4". I don't think that is a big deal though, as and l haven't heard about anyone shearing the shaft because of this yet. There's guys who swear by this combo, like subfloor, who has made 100s of passes on his 427, A6, Z06 drivetrain, running ~1.2x 60' times with the front wheels dangling out of the hole. If it works for him...
Having said that, if I had to do it over again, I would probably just go with 3.15s and do over the stock A6 diff with a few upgrades.
I like the 3.42s, but they make 1st gear almost totally useless, IMV.
My recommendation would be to get an upgraded A6 diff from RPM with 3.15s.
Old Jan 27, 2016 | 08:25 AM
xBoostx's Avatar
xBoostx
Is this so even in the base car have same spline as the Z ?
Old Jan 27, 2016 | 09:03 AM
timd38's Avatar
timd38
Base manual is 27 but auto are 30. Z06, ZR1 manuals are 30, so they should bolt up.
Old Jan 27, 2016 | 09:28 AM
xBoostx's Avatar
xBoostx
Thanks Tim seems you are rite it looks like they have one A6
Old Jan 27, 2016 | 09:37 AM
timd38's Avatar
timd38
I have a base car and built a whole diff from parts. It started as a ring and pinion, then a Quaife, then HD out put shaft, then the bigger pinion bearing, then a cooler, so I ended up buying the remaining parts to build a whole diff. The issue is that I ended up spending $5K, but I got what I wanted.
Old Jan 27, 2016 | 03:41 PM
HOXXOH's Avatar
HOXXOH
If you're not racing the car anymore, just stick in another 2.56 and be done. No other changes needed.
Old Jan 27, 2016 | 03:58 PM
xBoostx's Avatar
xBoostx
And now you know how to mess with it
Old Jan 27, 2016 | 07:47 PM
xBoostx's Avatar
xBoostx
There's no other changes needed to stick in a 2.73 either.
Old Jan 27, 2016 | 09:25 PM
HOXXOH's Avatar
HOXXOH
A change in the tune to correct the speedo would be needed.
Old Jan 27, 2016 | 09:51 PM
xBoostx's Avatar
xBoostx
Is very simple though..
Old Feb 2, 2016 | 06:53 AM
ZHZ-416ci's Avatar
ZHZ-416ci
I have a question for all if you don't mind
does the 2005 C6 gear (3.15) fit on 2008 base?
To Differential
Old Feb 2, 2016 | 06:54 AM
ZHZ-416ci's Avatar
ZHZ-416ci
Old Feb 2, 2016 | 08:27 AM
Former Vendor
The gear itself will not fit on the output shaft of a base model automatic car. It will however fit a base model manual output shaft.
But the complete differential will not fit either transmission. 05 Differential cases are 05 specific and terribly unreliable.
Old Feb 2, 2016 | 09:50 PM
oklahoma's Avatar
oklahoma
I have a 2008 c6a6 2.56 take out diff after going to the 2.73. It has 23000 miles on it and is available if you want. My zip code is 29607. Make me an offer.
