Swapping 6l80e transmissions
Old Jan 30, 2016 | 10:02 PM
secrt0007agt's Avatar
secrt0007agt
St. Jude Donor '15
Default Swapping 6l80e transmissions
My 2011 GS A6 has a problem and I was getting ready to send it out and have it rebuilt, but I found a 2011 Camaro SS 6l80e that is still in the wrapper, newly rebuilt......is it a big deal to interchange these two 6l80e's? Thanks
Old Feb 1, 2016 | 07:56 AM
xBoostx's Avatar
xBoostx
It is not unfortunately i may have to change mine I have already changed the converter twice and swapped the diff once on my back.
As far as I know there's just one 6L80 shaft and on the corvette is 30 spline so be sure is a 30 spline input shaft the trany should be the same.
Are you doing the job yourself I can send a few pointers your way if so.
Old Feb 1, 2016 | 08:05 AM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
They're absolutely not interchangeable.
Old Feb 1, 2016 | 09:15 AM
secrt0007agt
St. Jude Donor '15
Default 6l80e
Thanks for the info, no I am have a shop do it, but I found a built 6l80e over the weekend and wanted to see if they interchangeable. Thanks
Old Feb 1, 2016 | 06:09 PM
xBoostx's Avatar
xBoostx
Great you chime in Subfloor I may have been saved as well I
wonder what's different if electronics or input shaft thank you for sharing.
Old Feb 1, 2016 | 06:16 PM
Supporting Vendor
The main issue is the output shaft. While I think you could conceivably convert it over, having to swap the output shaft requires the entire transmission to be torn apart.
Old Feb 1, 2016 | 09:35 PM
secrt0007agt
St. Jude Donor '15
Default Per Century Trans
Sorry, the Camaro tranny will not interchange into a Corvette. The Vette case, pump housing & output shaft are unique to the Vette. Even the bolt pattern on the torque converter is different. The main problem is the case. A Vette differential cannot bolt up to a Camaro/truck case.
Old Feb 1, 2016 | 10:21 PM
xBoostx's Avatar
xBoostx
Great guys I can see different case and output shaft leaves out the possibility, is clear statement for others to learn as well.
Thanks secrt0007agt and subfloor for your contribution.
To Swapping 6l80e transmissions
