NPP controller questions
Old Jan 31, 2016 | 04:58 PM
redbird555's Avatar
redbird555
Default NPP controller questions
So guys I'm converting my car from stock exhaust to NPP. I would like to somehow utilize the system so that it opens at rpm like the factory does as opposed to having one or the other with a fob. I know sunset used to make a commander that could do that, is there any current controller that allows an rpm/vacuum function to operate the mufflers or are we stuck with just the npp in a box option? If so has anyone just run vacuum straight off the motor? I would think at a certain throttle input the vacuume would become non existent and the blades would open anyway.
Old Jan 31, 2016 | 10:29 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You can just install the factory NPP controller. The NPP valves are controlled by a separate module, NOT the engine control module or body control module.. and the good news is it's fairly cheap. $75 or so. Then the vacuum solenoid you need is about $75 also.
Basically the NPP control module connects to one of the CAN buses, connects to power, and connects to a solenoid that turns the solenoid on/off that connects the flaps to vacuum. It's basically a standalone computer that decides when to open/close the NPP flaps. It's not bad to install.
Here are some pictures and a wiring diagram from when I installed mine. It wasn't too bad to install.
https://www.corvetteforum.com/forums...post1591003860
Old Feb 1, 2016 | 06:12 AM
redbird555's Avatar
redbird555
Thanks man, do you happen to have a part number for the control module there I'm having trouble finding it. However I did manage to find the vacuum solenoid. Also i dont have dash logic so would I still wire it to the serial bus plug via an "orange" wire like you have and they wire everything else to hot/ground as normal? Would it still be controlled by the mirror swtich then or would it just function as a normal npp car.
Old Feb 1, 2016 | 08:42 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yes it needs to be wired to serial bus regardless.. that's how it gets info about when it send the "open" or "closed" signal. It reads RPM, throttle, etc. from the serial bus data.
Amazon.com: Corvette C6 LS9 Export Tailpipe Tail Pipe Exhaust Flow Control Module 20779365: Automotive Amazon.com: Corvette C6 LS9 Export Tailpipe Tail Pipe Exhaust Flow Control Module 20779365: Automotive
This is the one I'm using.. there are a few different versions that are setup to open at different times (I'm not sure the exact differences). If you search for this part number on one of the GM parts websites you can probably find the # for the "regular" one
Without dash logic the mirror switch won't do anything regarding NPP
Did you find the part number for the connectors on the NPP controller? I think they're in that thread I linked to.. if not they are in another one I can dig up.
Old Feb 1, 2016 | 08:50 AM
redbird555's Avatar
redbird555
It's just the normal vacuum solenoid correct? Comes with a few lines and mounts near the back of the manifold? If so then yes and ok so that will get wired into the bus, there's nothing in the tune that needs to be turned on though so it reads rpm and gives power? In other words it's active even though the car didn't come with npp
redbird555's Avatar
redbird555
Also where did you get the electrical plugs for the module
Old Feb 1, 2016 | 08:55 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
No tune changes since it's own little computer and is totally separate from the ECM/BCM. Just plug it in and it should work.
Connectors for controller I figured out and posted here:
https://www.corvetteforum.com/forums...post1590715392
Connector for solenoid is a fuel injector connector basically.. got mine here:
Amazon.com: MotorWest Performance C113 - EV1 Female Fuel Injector Connector With Attached Pigtail: Automotive Amazon.com: MotorWest Performance C113 - EV1 Female Fuel Injector Connector With Attached Pigtail: Automotive
The solenoid is a weird one the way it works, so I used the real GM one. It comes with some hoses, etc. I just pulled those off and ran my own lines.
Solenoid part number is 25794609
Old Feb 1, 2016 | 12:41 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Pretty cool info!
Thanks,Matt
To NPP controller questions
