Please Help identify this
If I had to take a stab in the dark, would dare to guess that someone did not check valve spring clearances, the springs coils bound up to bend some push rods, and instead of the lifter being under pre-load, they where not enough rebound with oil pressure to blow the retainers out of the lifters.
As for the dark ones that appear to be thicker in diamiter, they look like piston pin locks that came loose from the pistons instead (or may just be parts of the lifter retainers if the same type wire).
The tiny spring is from a valve seal. They don't fall off by themselves.
If you're lucky, it's only a broken valve spring that started the process, which now has progressed to a lifter.
Stop driving the car now, unless you want to swap whole engines, since this one could go bad in a heartbeat.
My guess it that you recently bought the car and the previous owner had a cam installed. You need to get more info on the cam and valve springs and how long since the install. Valve spring life depends on the cam and how hard it was run.
Since you had someone else do an oil change, I'll assume you're not real familiar about how stuff works. So get a rental car or something else to drive until you find a performance shop where you can get the car towed and checked. If it was me, I wouldn't even touch the starter button without pulling the valve covers first to see the extent of damage.
Sorry this happened to you, but don't disregard this and continue driving the car. Also, since you own a modded high performance car, you need to learn all you can about the required maintenance. This forum is a great place to learn and ask questions, but it's not the only place and some of the info here is not the best either. I'm hoping the best of luck for you.
Not good.
