2005 oem ac compressor part #
Old Feb 6, 2016 | 10:31 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default 2005 oem ac compressor part #
Having good trouble locating a ac compressor for my 2005 (not through a dealer). Anyone know oem part # for 2005 ls2?
Old Feb 6, 2016 | 12:17 PM
irok's Avatar
irok
Default this
compressor p/n 89019337. $387. at dealer 05 to 13. 6.0 & 6.2 all the same
Old Feb 6, 2016 | 01:50 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
or ACDelco 15-21132 for LS2 one
ZR1 one adds 6 rib pulley in case you ever need it.. ACDelco 15-21745 ($249 on Amazon)
Old Feb 6, 2016 | 03:15 PM
C U IN REARVEIW
I purchased the one you suggested (zri) earlier (fall),but my trick flow HB only has 4 rib pulley to run ac compressor. I REALLY don't want to change that again...
Old Feb 6, 2016 | 05:20 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Should be fine to run 4 rib belt on it. I run an 8 rib balancer and 6 rib main belt no problems. The plus being that if you ever need to run a 6 rib then you already have the right compressor
If you end up going with a 4 rib instead and want to get rid of the ZR1 compressor let me know, I might buy it off of you if Amazon won't take it back
Old Feb 6, 2016 | 11:19 PM
C U IN REARVEIW
Already returned it
Old Aug 11, 2016 | 11:19 AM
Slick 6MT's Avatar
Slick 6MT
So the ZR1 (ACDelco 15-21745) will fit an LS2 perfectly? The only difference is the two extra ribs? Does anyone have any experience with this?
Thanks!
Old Aug 11, 2016 | 06:55 PM
C U IN REARVEIW
Thanks!
Yes,zr1 ac compressor bolts right up and works great
Old Aug 12, 2016 | 06:25 AM
Slick 6MT's Avatar
Slick 6MT
Awesome. Thanks!
To 2005 oem ac compressor part #
