Question: how do I remove the hood insulation?
Old Feb 7, 2016 | 12:06 AM
boonie c4's Avatar
boonie c4
Default Question: how do I remove the hood insulation?
I need to know how to remove my hood insulation? dose it require any special tools or parts?
thanks boonie
Old Feb 7, 2016 | 12:51 AM
5knives's Avatar
5knives
It's very easy. Just pull out all of those black plastic tabs. If you have a trim puller tool (kinda looks like a 2 prong fork) that will make it easier without damaging the tabs. If not, a flat heat screwdriver and/or needle nose pliers will work. There's nothing to it.
Old Feb 7, 2016 | 07:48 AM
timd38's Avatar
timd38
Depending on how old your car is, they may break, so if you plan to install a different liner, I would recommend new retainers.
To Question: how do I remove the hood insulation?
