Sway Bars
Old Feb 7, 2016 | 02:25 PM
Travis S's Avatar
Travis S
Default Sway Bars
Hi everyone,
I'm sure this has been beat to death on here but I haven't found the right link yet. I have an 05 Convertible F55 running CCW Wheels with 275 fronts and 325 rears. I don't track the car but do like to play on the back roads here in Oregon. Car seems to wonder on the road more then I would like and has way to much body roll. Any suggestions on where to look or personal experience would be greatly appreciated.
Old Feb 7, 2016 | 02:50 PM
timd38's Avatar
timd38
What is on it now? Since you have 325 tires, my bet is that you have a wide body kit, so Z06 bars would work well, but you may already have them.
Old Feb 7, 2016 | 03:00 PM
Travis S's Avatar
Travis S
Stock bars and shocks. Still a Narrow body. Stuffed the 325s under the fenders via offset.
Old Feb 7, 2016 | 03:04 PM
timd38's Avatar
timd38
Very nice!
I have Pfadt bars. You can adjust them to your driving style.
Many good choices out there. LG has great bars and GM has T1 bars that you can as well.
Old Feb 7, 2016 | 03:09 PM
Travis S's Avatar
Travis S
Very nice!
Thank you!
I was looking at Pfadt bars, Witch ones do you run? Did they make the car really stiff or is there still a good drivability to them?
Old Feb 7, 2016 | 03:13 PM
RicK T's Avatar
RicK T
I'm sure the tires are adding to your "wandering". Might try an alignment tweak. Find and talk to a good alignment tech at a good shop.
As for bars, the popular mod for F55 cars is to go to the Z51 bars. Fairly inexpensive and most luv the result. But, with your tires, you may want to go to the Z06 rear bar. Depends on how picky you are I suppose.
Old Feb 7, 2016 | 03:17 PM
Travis S's Avatar
Travis S
I was leaning Z06 size bar because of the tires as well, Thanks for the input
Old Feb 8, 2016 | 09:09 AM
LFZ's Avatar
LFZ
I'd go Z06 bars...or Hotchkis bars if you want a little adjustability there.
I wouldn't go Pfadt...well...because they're Pfadt.
LG or T1 bars are great...but I'd say they would be a bit much for stock shocks/leafs...JMO.
Old Feb 8, 2016 | 10:58 AM
Travis S's Avatar
Travis S
To Sway Bars
